PO6 to P28 HOW?
Old Oct 16, 2005 | 06:02 PM
THC07's Avatar
Default PO6 to P28 HOW?
How do you convert a po6 to a p28, and how do you make it so it is socketed. any ecu info would be great. im trying to learn all about it.
Old Oct 16, 2005 | 06:06 PM
m00nr0ck Si's Avatar
Default Re: PO6 to P28 HOW? (THC1107)
go to Kenji's web site and he will sell you everything you need to convert it for pretty cheap or he will do yours for like 80. or he will sell you one for like 150!
Old Oct 16, 2005 | 06:13 PM
THC07's Avatar
Default Re: PO6 to P28 HOW? (dorkoftheyear)
Yes i want it done but i want to know the difference between po6 and p28. and how to convert
Old Oct 16, 2005 | 06:26 PM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC1107 &raquo;</TD></TR><TR><TD CLASS="quote">Yes i want it done but i want to know the difference between po6 and p28. and how to convert</TD></TR></TABLE>
the difference lies in the p28 having the additional hardware necessary to trigger the VTEC solenoid. if you want to know how, search the wiki over at pgmfi
Old Oct 16, 2005 | 07:20 PM
Ace0246's Avatar
THC, (that stand for Tetrahydrocannabinol?)
It's all documented on the pGmFi.OrG wiki. Honestly, Honda-Tech isn't the place to start learning about ECU chipping. I would recommend heading over to http://WWW.PGMFI.ORG and going to the WIKI and finding the "ECU Chipping 101" Article. Good luck with your endeavors!
Old Oct 16, 2005 | 07:33 PM
THC07's Avatar
Default Re: PO6 to P28 HOW? (Ace0246)
yes lol THC. thanks for the info on web page.
Old Oct 16, 2005 | 07:36 PM
HiProfile's Avatar
Both boards are essentially the same, the p06 just doesn't have the relay-thing to activate vtec. When the components are added, it functions just like a p28. To use vtec and p28 maps, you need a p28 chip put in the socket.
Old Oct 16, 2005 | 07:51 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace0246 &raquo;</TD></TR><TR><TD CLASS="quote">THC, (that stand for Tetrahydrocannabinol?)
!</TD></TR></TABLE>
Damn i would have never thought of that. Googled it and you had to be a science major to have figured that out or be a major in what it is
Either way like said already PGMFI.org is the place to be. Thats how i learned.
Old Oct 16, 2005 | 10:08 PM
THC07's Avatar
Default Re: PO6 to P28 HOW? (HiProfile)
So if i put a spoon chip for a p28 in a po6(with active v-tec) then all is the same even the fuel map?
Old Oct 17, 2005 | 01:41 PM
kenji's Avatar
25 Year Member
Yes, if you have converted a P06 to VTEC (added the necessary components) the Spoon chip will run EXACTLY the same as it would in a P28.
If you need me to convert your P06 or have tech questions email me at kenji211@tampabay.rr.com
-kenji
Old Oct 17, 2005 | 04:37 PM
THC07's Avatar
Default Re: PO6 to P28 HOW? (kenji)
If i were to get a po6, what would be the steps to convert. is this somthing that i can do? do i just have to run wires to ecu form somewhere?
If you know of a web site that can teach me all i want to know about ecu's please let me know. im trying to learn all this good stuff, so when i get my smogtech lic. i can do ecu coversions.
Old Oct 17, 2005 | 04:38 PM
THC07's Avatar
oops,, also wanted to know if my p2p is worth a dam or not. can it be changed in any way?
Old Oct 18, 2005 | 09:33 AM
Ace0246's Avatar
p2p isn't worth much in the chipping/tuning industry. OBD-2 ECUs are a much different design. head on over to http://www.pgmfi.org and check out the WIKI and find the article labelled "ECU Chipping 101" to get started chipping (which you would have to do to add VTEC), then you can find the articles on the same WIKI/web site for info on converting to VTEC. honestly, Honda-Tech isn't the place to learn about chipping ECUs, rather it is PGMFI.ORG. good luck!
si0385.
22
Sep 18, 2019 05:41 PM
B16CivicEX
Jul 27, 2006 09:44 AM
jdm'dc2sc61
Jul 2, 2005 12:23 PM
khang77642
Sep 3, 2002 06:06 PM
