will a dohc 1.6 dc header off a zc fit on a b16a1
Im not sure how 100% correct I am...
But the SOHC ZC is a JDM d16a6, the 88-91 si motor. So the headers will not be interchangable between the two series of engines.
Someone correct me if I'm wrong.
yeah theyll fit hes talking about the dohc zc(non Vtec) which is like a b series. Yeah a lot of dohc zc parts are interchangeable with b series, just like the sohc zc(v-tec) is interchangeable with sohc d- series v tec motors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACERX72 »</TD></TR><TR><TD CLASS="quote">yeah theyll fit hes talking about the dohc zc(non Vtec) which is like a b series. Yeah a lot of dohc zc parts are interchangeable with b series, just like the sohc zc(v-tec) is interchangeable with sohc d- series v tec motors</TD></TR></TABLE>
You sure about that? Can you tell me what other DOHC ZC parts are interchangeable with a B-series?
I have DOHC zc headers on my SOHC zc...the dohc zc has interchangeble parts d-series....what parts can u use for a b-series off a dohc zc???????? besides tps ....jus cuz its dohc dont mean u can do it...i have a sohc block with a dohc zc head on it
NO, you are very wrong about this, zc is in the d-series family.. zc exhaust ports are offset by a few mm from the d-series.
No, the Zc header will not fit as it is an D- Series part, D-series parts stay in the D-series family,im not flaming you but thats why there are SERIES..Just some adivse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driveahonda »</TD></TR><TR><TD CLASS="quote">
NO, you are very wrong about this, zc is in the d-series family.. zc exhaust ports are offset by a few mm from the d-series. </TD></TR></TABLE>
*Ed Macmon* you are correct sir!
You are 100% INCORRECT
The DOHC ZC takes a SOHC header, a B series header will not work.
Yes this guy is right don't listen to the others. The ZC is not anywhere near the same as a b-series.
ok everyone listen to this...i have a dohc zc...even tho it is considered a d series engine..a d16 or d15 header will not fit on it..it is true that it is about 3mm off witch is actualy quite a bit..i bought myself headers for a d16 and had to do my own port job to make it match up to the ports..and no b-seriers wont fit..
rice a roni
Apr 13, 2006 04:59 PM
bazookatooth
Feb 10, 2005 12:20 AM
