wtf! is this my headgasket or something else? please help
Old Oct 16, 2005 | 04:18 PM
hb_guy's Avatar
Default wtf! is this my headgasket or something else? please help
1990 civic ex with 209k
bought from old lady, car was very well taken care of.
lady said that it needed a head gasket, i could drive it home but it overheated and used oil. i had it towed to my house the other day and this is what i found when i looked at it today finally.
i pulled the plugs and the two center plugs were really dark(black-charcoal almost). i looked into the center holes and the piston tops were the same-dark black and kinda sludge looking. the two outer plugs were worn but not as bad, the piston tops in the outer plug holes(cylinders 1 and 4, were not black and shitty looking like the others.
i put the plugs back in and started the car up and let it run for a while(like 20 mins), and it did not over heat, but there was an antifreeze smell and very slight smoke(barely noticeable) coming from the head/block area, but nothing out the exhaust and no weird noises.
Is this my headgasket? i am going to do a compression test tomorrow and a leakdown if i can borrow one. there was also oil sludge buildup on the block where the engine code is stamped, pretty thick. not too sure what to think, so once again i am turning to honda tech for some direction.
Old Oct 16, 2005 | 05:05 PM
slomofo's Avatar
GDD Member
Bad head gasket.
Easy fix, I timed myself last time, it only took 19 minutes to pull the head off using air tools, 1 day in the machine shop, and 45 minutes to re-install.
Old Oct 16, 2005 | 05:12 PM
hb_guy's Avatar
Default Re: (slomofo)
thanks
Old Oct 17, 2005 | 07:21 PM
hb_guy's Avatar
Default Re: wtf! is this my headgasket or something else? please help (hb_guy)
UPDATE: fans work, does not overheat sitting at idle, let it run today for almost an hour.
i do notice a very light ticking noise coming from the distributor area-it is not my valves-it is coming from or around the area near the distributor-right by it or in it. any ideas to this? just curious, doesn't seem to be a prob but concerned nonetheless-head is coming off tomorrow!
Old Oct 18, 2005 | 02:44 AM
Cuda70's Avatar
Just a little suggestion... Have the head checked before you re-install it. Guides, springs, the works. While you have it off and in the machine shop, might as well do it right; right?
Are you sure the ticking is not the injectors?
Old Oct 18, 2005 | 05:02 PM
hb_guy's Avatar
Default Re: wtf! is this my headgasket or something else? please help (Cuda70)
the sound is coming from the dizzy area. injectrors making noise? can you ellaborate? and yes my head will be in the shop getting checked and resurfaced
Old Oct 18, 2005 | 07:10 PM
Slow ass EF's Avatar
the injectors normally make a clicking noise when they are firing
Old Oct 18, 2005 | 07:34 PM
hb_guy's Avatar
Default Re: wtf! is this my headgasket or something else? please help (slow *** ef)
damn, i never noticed this on my 4 other ef's - including my b16 hb.. that's weird.
Old Oct 19, 2005 | 04:18 PM
hb_guy's Avatar
UPDATE AGAIN:
did compression check and these were the results (191, 184, 179, 185) respectively. should they be within 5 or 10% of each other i forget. should i still do the headgasket?
Old Oct 19, 2005 | 08:41 PM
the numbers sound decent. the best way to test your head gasket tho is to check the coolant with the hydrocarbons tester
Old Oct 20, 2005 | 05:40 AM
hb_guy's Avatar
hydrocarbons tester, did search, but not too helpful. i might just pull the motor and drop in my z6. i dont understand why the lady i bought it from said it was overjeating, plus it has lots of oil in it, i might drain some later to see what's up.
thanks
motegicivic
Mar 19, 2012 11:59 AM
thomas.owns
18
Aug 11, 2009 05:50 PM
hb_guy
16
Oct 20, 2005 11:05 AM
rasinhell
11
May 30, 2005 10:33 AM
arw321
Apr 29, 2002 06:03 AM
