For all you know it all's.......LOL
Old Mar 5, 2002 | 08:34 PM
ic108's Avatar
New User
Default For all you know it all's.......LOL
i did a search on this and i could not find what i was looking for. here's the deal........i have a B18C1 and am contemplating on what compression to run
i am either going to be running 01 ITR cam, skunk stage 1's or toda A's...........
i was thinking of purchasing the JDM ITR pistons (11:3:1) or the USDM pistons (10:8:1) or USDM pistons in conjuction w/ mugen head gasket (11:1:1)
here is the question..........is there going to be any diff in power b/t the lowest and the highest compression listed in this post???? i can get all USDM acura parts at cost vs paying more for JDM parts. what do you think would be best.
ps. no flames
Old Mar 5, 2002 | 08:37 PM
FSTASNTZ's Avatar
Default Re: For all you know it all's.......LOL (ic108)
Why not consider the B16A pistons from the Del Sol? Should be in the mid-high 11s. Would you also be able to get those at a lower cost since they are USDM parts?
Jason
Old Mar 5, 2002 | 08:50 PM
ic108's Avatar
New User
Default Re: For all you know it all's.......LOL (FSTASNTZ)
Jason
i would think that the P30 pistons are better for a higher lift/duration cam.........what i will be purchasing will be very mild and from what i here across HT, low 11's would be best. i just want to know if there is any diff in power b/t (10:8:1 and 11:3:1) compression
Old Mar 5, 2002 | 10:37 PM
Mr. Softee's Avatar
I used to have b16s with type r cams in a gsr block with gsr head milled 26. It was a tad too much copmression, would have been perfect with a non milled head. Id do that if i were you.
Old Mar 5, 2002 | 10:48 PM
GokuSSJ4's Avatar
Default Re: For all you know it all's.......LOL (94goldjungsr)
run the jdm itr pistons , and using a gsr i wouldnt recommend a thin head gasket !
bad experience
just run an oem 3 layer head gasket and you should be good at 11.3 do to the gsr head !
iheartmyctr
Jul 3, 2008 07:01 AM
^Sammy]!.
Feb 2, 2006 11:16 AM
^Sammy]!.
Feb 2, 2006 08:59 AM
aser1z
May 27, 2005 06:51 PM
Spoon97R
May 1, 2002 10:30 PM
