NEED HELP FAST
I broke something today(long story) on my car. I dont know what its called. It connects to the intake and there is a line going to the middle of the valve cover. Also if anyone has one that they can sell me for cheap?
99 d16y8
thanks.
99 d16y8
thanks.
14 views and no answer. sorry i know i bumped it soon. but i need a reply because tomorrow 1st thing in the morning im going to the dealer.
no point to bump it if its alrdy at top alrdy
http://slhondaparts.com/browse...=true
looks like part 24
looks like part 24
Hi- This piece is called the "Air Assist Valve". It is part number 36281-p2p-A01 I believe. I paid aobut $95 at my local honda dealer.
I broke the same piece last year when installing my turbo.
Since that piece is broken off you can remove it with a 21mm socket, I think- possibly 22mm?! You would be best to replace it with a o2 sensor socket - As you will need the slot in the socket for the plastic piece - the one you broke. Mine was on there pretty F*cking tight! Sucks man, sorry! Good luck
*Note, I tried to JB weld it back on... NO GO!
I broke the same piece last year when installing my turbo. Since that piece is broken off you can remove it with a 21mm socket, I think- possibly 22mm?! You would be best to replace it with a o2 sensor socket - As you will need the slot in the socket for the plastic piece - the one you broke. Mine was on there pretty F*cking tight! Sucks man, sorry! Good luck
thanks for the help guys. Damn,. that sucks. There is no way i can pull out 100 dollars from my butt right now. not even 50. Right now i got a mesh thing there as a filter. It runs well for now untill i get a new one. Thanks again.
strikerflo
Sep 16, 2007 07:54 PM
