plx m-300 display problem
Old Oct 16, 2005 | 02:45 PM
ottobell22's Avatar
Default plx m-300 display problem
I don't know if my plx m-300 is reading properly. The display fluctuates between the readings 00.00, rich and 14.67, but mostly it show 00.00. I haven't tuned my b16 turbo set up yet, and I'm using a hondata ecu.
Old Oct 16, 2005 | 02:55 PM
nota-eg's Avatar
Default Re: plx m-300 display problem (ottobell22)
Did you cut any of the wires or anything? The PLX shouldn't go as low as 00.00. I think after 10.0:1 AFR it just reads rich.
You may have to send it back to have them fix it.
Old Oct 16, 2005 | 03:26 PM
SHystrdyGSRtdy's Avatar
Default Re: plx m-300 display problem (nota-eg)
do you have a noise filter?
Old Oct 16, 2005 | 03:40 PM
ottobell22's Avatar
Default Re: plx m-300 display problem (SHystrdyGSRtdy)
Nothing cut and no noise filter.
Old Oct 16, 2005 | 04:47 PM
try installing a noise filter.. look at the online manual @ http://www.plxdevices.com and search filter in the m300 install guide... it'll give you some information about it.
iplayloudly
Jan 2, 2009 07:21 PM
thesilverbullet
Honda Motorcycles
13
Sep 30, 2004 07:39 PM
