ok to run 205/65R15 studded snows?
Old Oct 16, 2005 | 01:40 PM
syntax.'s Avatar
Default ok to run 205/65R15 studded snows?
93 vtec lude, stock suspension, stock rims
I am thinking about buying a barely used set of studded snows for this winter. However they are 65's instead of the stock 55's, so the sidewall is a bit taller.
What are the downsides to running them, if any? Has anyone done so and do they rub or have any other negative effects i should take into consideration?
Thanks in advance
Old Oct 16, 2005 | 02:32 PM
AndyD's Avatar
Default Re: ok to run 205/65R15 studded snows? (syntax420)
I will be running them for a 3rd year in a row this year. Even with my car lowered a little on Tein Basic coilovers, I didn't have a problem. If you have a stock suspension, you will be fine.
Old Oct 16, 2005 | 06:50 PM
integra15's Avatar
Default Re: ok to run 205/65R15 studded snows? (AndyD)
go with 195/60 15's less chance of rubbing
robbyptown
Honda CR-V & Element
15
Jun 11, 2013 08:21 AM
94typeR
Apr 12, 2007 05:07 PM
type B16
Nov 23, 2006 11:48 AM
Flux
Oct 18, 2002 11:03 AM
Lo-Buck EF
May 27, 2002 07:20 PM
