who has zc/vtec
Old Mar 5, 2002 | 08:09 PM
daniel89civ's Avatar
Default who has zc /w d16z6 head
i maean
zc block dohc & d16z6 head sohc vtec
people who went to the meet 03/03/02 in rosemead ca should know their user name
i dont know his user name but , he has zc block and d16z6 head
[Modified by daniel89civ, 12:11 AM 3/6/2002]
Old Mar 5, 2002 | 08:25 PM
balistic CRX's Avatar
Default Re: who has zc/vtec (daniel89civ)
are you on some thing. i think your trippin. it wont match up
Old Mar 5, 2002 | 08:36 PM
AbaZ's Avatar
Default Re: who has zc/vtec (balistic CRX)
No the question is are you on something? He is more then likely talking SOHC ZC and a z6 head, yes they will match up.
DOHC ZC & z6 head wont. that would be stupid to do anyways.
I belive the SOHC ZC pistons are Domed, (rumor) and this will create a even higher compresson on a mini-me a6.
Jeff
[Modified by AbaZ, 5:36 AM 3/6/2002]
Old Mar 5, 2002 | 09:00 PM
Mugen Dom's Avatar
Default Re: who has zc/vtec (AbaZ)
the sohc is a d16a6 simple as that but its a jdm d16a6 that has 10 hp more but i doupt it has domed pistons hondacrx has one ask him to take off his head and check as for the question havent u been around for a good period of time? u ask questions u know u shouldnt ask. Why is that im not trying to be a dick but i think u know that a zc is a dohc motor and totally diff block all together and if u read any of the posts ud also know that the sohc zc is the same as a us zc but the head is diff to my knowedge. And u should know better than to ask about quarter mile times u know everyones gonna go abck and forth about some crap.
Old Mar 5, 2002 | 11:10 PM
Default Re: who has zc/vtec (jdmB18hatch)
i saw the car the block says " zc" dohc and d16z6 or y8 head those are the sohc vtec i know is a hibird
if you see the engine block code it has a big "ZC"
abaz, breau , come on
[Modified by daniel89civ, 12:25 AM 3/6/2002]
Old Mar 6, 2002 | 12:37 AM
[626]95-GSR's Avatar
hmmm... i doubt that a SOHC head will even bolt onto a DOHC block.. why would someone want to do this anyway?? If im not mistaken, arent there some sohc ZC vtec motors (rare)?? if so.. thats probably what you saw. if not.. why in the world would someone want to do that to a dohc ZC motor? that would be straight up stupid. i think this has been covered before. dohc ZC/vtec NOT POSSIBLE.. and why the hell would you want to do that anyway?
[Modified by [626]Rj-SiHatchy, 9:39 AM 3/6/2002]
Old Mar 6, 2002 | 07:46 AM
afstlsvtec's Avatar
Default Re: who has zc /w d16z6 head (daniel89civ)
if you want to do it you have to use a 96 and up sohc vtec head cause that is the only one that will bolt up right, i was going to do that but i want ls-vtec, it is a good start but i would suggest to build the bottom a little bit, cause you do not want to go through all that trouble and have some **** blow up or spin a bearing or something, those rod bearings spin after 9200 rpm's good luck
Old Mar 6, 2002 | 07:56 AM
Mugen Dom's Avatar
Default Re: who has zc /w d16z6 head (afstlsvtec)
the d series SOHC heads are all teh same no dohc zc will mate with a sohc head it is not possible. U have been around long enough to know this do u not read any posts here?
Old Mar 6, 2002 | 07:57 AM
NawTeeCRX's Avatar
Default Re: who has zc/vtec ([626]Rj-SiHatchy)
There IS such thing as a SOHC ZC motor. It's some weird JDM SOHC engine. I've seen it listed as a 1.5 some places, and a 1.6 in others. I saw a 1.5 SOHC japanese ZC motor once at a shop, but didn't really pay too much attention to it. Do a search on it... I'm pretty sure it's been covered before
Old Mar 6, 2002 | 08:04 AM
WuShu's Avatar
New User
Default Re: who has zc /w d16z6 head (jdmB18hatch)
your talking bout a sohc zc trust me, and i seriously doubt the block has dohc stamp on it. My block says d16(something)zc
your just seeing the zc and assuming its a dohc, but no sir they did come in sohc form. I just cant see putting a sohc vtec head on a zc block, that would look pretty ghey, big block then it tapers at the head? no way dude, but hell prove us wrong, post a pic
Old Mar 6, 2002 | 10:02 AM
CimorelliCRX's Avatar
My ZC says "ZC" on the block, thats it..
Old Mar 6, 2002 | 10:38 AM
marty's Avatar
Default Re: who has zc/vtec (NawTeeCRX)
Yeah its called the US Si motor aka D16A6 not a ZC.. Of all the years ive been in this buisness I have never heard anyone call a D16A6 a SOHC ZC. ZC was meant for one motor and it was the DOHC 1.6 NON VTEC JDM CR-X Si EF7. The ones before that were 1.5L and 1.5X which were D15B7's. There were no " JDM SOHC ZC mumbo jumbo crap " i hear you guys always talk about.
EF2- D15B 4 Door Civic
EF3- Civic Si DOHC ZC Motor
EF6- D15B 1.5L CRX 15X/15X-G Special
EF7- DOHC 1.6 non-vtecZC CRX Si
EF8- DOHC 1.6 VTEC CRX SiR
EF9- DOHC 1.6 VTEC Civic SiR
So IF I listed ALL the EF's made in Japan that year with the motor specs of what car came with what motor.. SOMEONE tell me where they got this idea of this SOHC ZC Mumbo Jumbo Crap.
Old Mar 6, 2002 | 10:47 AM
CRX-RX's Avatar
Default Re: who has zc/vtec (MugenEF7)
Man, you guys are soo locked in your ways, and won't beleive anything new. I bet five years ago none of you would beleive a B16 would fit into a CRX. Anyways, I know I've been over this before here, but go http://www.superhonda.com/forum/show...&threadid=6618 and check it out for your self. I have put a DOHC head on a SOHC block, and there's no reason it won't work the other way. It's not a direct bolt on because of the oil passages, but the bolt pattern is the same.
[Modified by CRX-RX, 1:48 PM 3/6/2002]
Old Mar 6, 2002 | 10:49 AM
afstlsvtec's Avatar
it is possible to pit a sohc vtec on a dohc zc block, i know i know people that have done it and i was going to do it too,the 96 sihc is the only one that has the same bolt pattern as the dohc zc,
Old Mar 6, 2002 | 10:50 AM
WuShu's Avatar
New User
dude its sittin in my car right now, damn it its times like this i wish i had a digicam. Ive heard its rated at 118hp, now short of someone mating a sohc head onto a dohc block which i dont think is possible, the motor sittin my car right now sure enough is a sohc zc, its stamped with the zc on it, d16(something)ZC, actually you can see it when you come to mariofest2.
marty's Avatar
Default Re: who has zc/vtec (CRX-RX)
I had a 94 B16A from a del sol fit into a hatchback lil more than 5 years ago when no one said it could be done.
Old Mar 6, 2002 | 11:03 AM
CRX-RX's Avatar
Exactly, and everyone probably didn't beleive you then right? Just like no one will beleive this can be done because it's more work than just bolting it together so the rumor got started that it <U>can't</U> be done, and look where we are now.
Old Mar 6, 2002 | 11:06 AM
marty's Avatar
thats affirmative.. it was a big WTF that cant happen.. or Photoshop king here.. and along the line of that BS. whatevers waht i know and you dont doesnt make a difference.. i just need to know and believe what i can base facts around
Old Mar 6, 2002 | 12:17 PM
Default Re: who has zc /w d16z6 head (beatdown88hf)
(beatdown88hf) you got mail
[Modified by daniel89civ, 1:35 PM 3/6/2002]
Old Mar 6, 2002 | 01:12 PM
2point6's Avatar
I just finished building one for a customer. Turned out really nice.
phoQ
22
Nov 11, 2021 07:59 PM
HondaHemi
Sep 4, 2005 11:12 PM
c.dub
Jun 13, 2004 03:46 PM
the jdmchop
Feb 3, 2004 10:12 AM
OnebadJdmEg6
Jun 9, 2003 01:56 PM
