Slight ticking coming from valves on 97 GSR.....what could it be???
Old Oct 16, 2005 | 12:13 PM
1JDMDOMINICAN's Avatar
Default Slight ticking coming from valves on 97 GSR.....what could it be???
Like the post says, today after coming back from the car wash, I heard a very slight ticking coming from my valves. I know its normal for VTEc B-Series to have a slight different sound coming from their valvetrain when compared to non-VTEC B-series, the ticking today was a tad bit higher than usual.
Someone once told me that VTEC motors need to have their valves adjusted over time. Maybe that's the case. Does this mean I have to adjust my valve lash? If so, can someone point me in the right direction as far as adjusting it? Or am I just over-reacting and the car is ok?
I rarely drive the car hard, only going into VTEC maybe 3 times in the week cuz I don't drive the car much...it usually sits M-F. (yes, I can count how many times in a week I hit VTEC..gas is expensive so I don't hit VTEC alot)
Please help me....is it valve lash adjustment it needs? How do I perform this myself on my car? Or am I just worrying too much?
Old Oct 16, 2005 | 12:31 PM
nitrofish420's Avatar
Default Re: Slight ticking coming from valves on 97 GSR.....what could it be??? (mugenda6)
Sounds like you need to adjust the valves. BTW, most if not all Honda engines need periodic valve adjustments, not just VTEC motors.
Old Oct 16, 2005 | 12:37 PM
Default Re: Slight ticking coming from valves on 97 GSR.....what could it be??? (nitrofish420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrofish420 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you need to adjust the valves. BTW, most if not all Honda engines need periodic valve adjustments, not just VTEC motors. </TD></TR></TABLE>
oh, ok...how do I go about performing this....I know how to do most things to my car, but this is something I'm going to be new to.
Basically working on my car is a learning experience everyday.
Old Oct 16, 2005 | 01:19 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenda6 &raquo;</TD></TR><TR><TD CLASS="quote">
Basically working on my car is a learning experience everyday.</TD></TR></TABLE>
Join the following site and download the factory service manual.
http://www.hondahookup.com/manuals/
Old Oct 16, 2005 | 03:22 PM
Here's a good writeup:
http://www.c-speedracing.com/h...t.php
Old Oct 16, 2005 | 03:50 PM
Hustla's Avatar
Old Oct 16, 2005 | 04:23 PM
.Kevin.'s Avatar
Default Re: Slight ticking coming from valves on 97 GSR.....what could it be??? (Hustla)
yes adjust your valves just get yourself i forget what they are called but they measure the clearance in the valves, it would be easier if you had someone help you, otherwise u just need that tool i mentioned (3$ at auto zone) a screw driver and i think a 10mm wrench
Old Oct 16, 2005 | 06:01 PM
Default Re: Slight ticking coming from valves on 97 GSR.....what could it be??? (Slow_CvC99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 &raquo;</TD></TR><TR><TD CLASS="quote">yes adjust your valves just get yourself i forget what they are called but they measure the clearance in the valves, it would be easier if you had someone help you, otherwise u just need that tool i mentioned (3$ at auto zone) a screw driver and i think a 10mm wrench</TD></TR></TABLE>
could it be a feeler gauge? I have those.
Old Oct 16, 2005 | 06:43 PM
TunerN00b's Avatar
I thought mine were loud as well, but they were perfectly within proper adjustment. I think its the injectors that make the majority of the noise. Either way, adjustment took me a good 2 hours, so just take your time, it isn't hard to do.
Old Oct 16, 2005 | 07:02 PM
.Kevin.'s Avatar
could it be a feeler gauge? I have those.</TD></TR></TABLE>
Ah yes thats it, now grab a manual flat head screw driver, remove he valve cover and check them out
Old Oct 16, 2005 | 08:09 PM
suzawa94's Avatar
would definately recommend this valve adj. tool. would save you ALOT of headaches.
not necessary but, also helps ALOT-offset feeler gauges
Old Oct 16, 2005 | 08:16 PM
Undercover_Skank's Avatar
Default Re: Slight ticking coming from valves on 97 GSR.....what could it be??? (suzawa94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">would definately recommend this valve adj. tool. would save you ALOT of headaches.
Old Oct 16, 2005 | 09:08 PM
Alexander's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">not necessary but, also helps ALOT-offset feeler gauges
I'm sorry but how the HELL are feeler gauges "not necessary" for a valve adjustment?
Old Oct 16, 2005 | 10:03 PM
old_school_dohcvtec's Avatar
Default Re: Slight ticking coming from valves on 97 GSR.....what could it be??? (Alexander)
hes just saying that off-set feeler guages are useful... but regular ones you need of course
Old Oct 16, 2005 | 11:41 PM
suzawa94's Avatar
Default Re: Slight ticking coming from valves on 97 GSR.....what could it be??? (old_school_dohcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old_school_dohcvtec &raquo;</TD></TR><TR><TD CLASS="quote">hes just saying that off-set feeler guages are useful... but regular ones you need of course </TD></TR></TABLE>
^^thank you for clarifying
Old Oct 18, 2005 | 06:09 AM
thankx guys, u've all been a great help.
Old Oct 18, 2005 | 08:46 PM
spddmn124's Avatar
Default Re: (mugenda6)
where can i buy/order the valve adj. tool??
Old Oct 18, 2005 | 11:29 PM
SwedBoy2999's Avatar
Default Re: (spddmn124)
Snap-On
http://buy1.snapon.com/catalog...talog
Old Oct 19, 2005 | 04:32 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexander &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sorry but how the HELL are feeler gauges "not necessary" for a valve adjustment?</TD></TR></TABLE>
yea that would be hard do do one without em.
Old Oct 19, 2005 | 05:49 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spddmn124 &raquo;</TD></TR><TR><TD CLASS="quote">where can i buy/order the valve adj. tool??</TD></TR></TABLE>
I bought one from amazon.com for $13 if I recall correctly.
Old Oct 19, 2005 | 06:21 AM
spddmn124's Avatar
nice thanks
egboostin6
Mar 8, 2007 07:30 AM
black_EM1
Jun 20, 2006 11:54 AM
raiden571
Nov 10, 2005 03:32 PM
crxfreak88
Mar 10, 2005 07:26 AM
Frosty_spl
Feb 21, 2002 03:19 PM
