password jdm fog lights for 99/00 em1 I NEED OF HELP
Well i recenlty bought the password jdm fog lgiths
my problem is that i tired to install it and none of the connecters from the kit fit onto the stock harness.
i tired to follow the instructions that honda-accesories.com had but no luck.
are the password jdm harness diffrent from the other fog lights out there?
i've done a search that was no luck also.
let me know if u've successfully installed the password jdm yellow fog lgihts.
if anything is unclear... jus ask.. ill try to clarify my self better
thanks
__________________
VEHICLE: EM1 FBP
thanks
__________________
VEHICLE: EM1 FBP
what i solved so far is that ... its a depo kit and does not install into oem harnesses
im wondering for the people who bought and have already installed this kit into your car: how did u go about installing it .. and can u help me out on this...
I installed this kit on my friend's car. It is independent from the rest of the car, meaning it hooks up separately except for the fusebox part.
1. There are red and black wires with ring terminals on them. This installs onto your battery.
2. There's a relay which runs towards the passenger side, I forgot if you have to ground it or not like the OEM one. Bolt that down in case.
3. There a long red wire with two connectors on each end. This runs from the engine bay harness to the interior harness via firewall. You have to run it yourself, there's a grommet near the clutch MC.
4. The engine bay harness should have the one connector that connects to the long red wire on the driver side.
5. For the interior harness, there's one connector that plugs into the fusebox. The instructions tell you which accessory slot it goes into. The fusebox is labeled with the accessory slot number. You match the number in the instructions with the position on the fusebox.
6. Connect the interior harness to the foglight switch.
7. Now connect the other end of the long red wire you ran through the grommet in the firewall to the end of the interior harness that accepts that connection.
8. This kit allows you to turn on the fogs without any keys in the ignition or the headlights turned on. So, make sure you press the switch to turn off so you dont drain your battery.
19crx93
Aug 14, 2010 01:52 PM
