Battery Connected the wrong way.
Old Oct 16, 2005 | 07:45 AM
HotImportNightHonda's Avatar
Default Battery Connected the wrong way.
So this girl I know put her battery in the wrong way and shorted something out. Now nothing comes on. I'm sure it's probably just a main fuse but was wondering if someone would be able to put me right on the source. Maybe they've seen it happen and know what to check. Any input would be great. Thanks,
Adrian
Old Oct 16, 2005 | 07:49 AM
.Ry's Avatar
.Ry
Default Re: Battery Connected the wrong way. (HotImportNightHonda)
Ive heard of this causing some real serious problems. Just start pulling fuses and check them. Bump for some more help.
Old Oct 16, 2005 | 08:35 AM
hatchi's Avatar
check the main fuse under the hood.
Old Oct 16, 2005 | 09:39 AM
suspendedHatch's Avatar
Default Re: Battery Connected the wrong way. (hatchi)
It's definately the main fuse. It's a big *** weird fuse that you actually have to screw down.
Don't blame a girl, we all know it was you! j/k
Old Oct 16, 2005 | 09:42 AM
Ricey McRicerton's Avatar
Default Re: Battery Connected the wrong way. (suspendedHatch)
My dad connected my jumper cables to my car after I killed it backwards as well. It blows the main fuse.
Old Oct 16, 2005 | 10:23 AM
Ace0246's Avatar
Default Re: Battery Connected the wrong way. (Ricey McRicerton)
yeah a friend of mine once connected jumper cables to my car wrong. it didn't blow any fuses though. just caused a constant 12 volt drain on the system and nothing worked. swapped the cables, and everything was good to go. guess i got lucky that either the battery or ignition fuse wasn't killed.
Old Oct 16, 2005 | 10:29 AM
Civic4less's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">My dad connected my jumper cables to my car after I killed it backwards as well. It blows the main fuse. </TD></TR></TABLE>
Yup same here. But it was this one chicks dad that was jumping my car. Just blew the main fuse. For the meantime he cut a soda can and put it there so I can get on my way. Haha.
Old Oct 16, 2005 | 10:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">It's definately the main fuse. It's a big *** weird fuse that you actually have to screw down.
Don't blame a girl, we all know it was you! j/k</TD></TR></TABLE>
Yeah that's what I figured but I know I'm not that big a stoner to connect the cables wrong. Where exactly is this fuse at?? In the box under the hood wright?? Thanks
Old Oct 16, 2005 | 10:53 AM
horizongreyEJ1's Avatar
LOL man i did the same exact thing don't just start pullin fuses look in the fusebox under the hood and locate fuse 80 (battery)A i think it is prolly blown just replace it and start up the car.
Old Oct 16, 2005 | 11:35 AM
transpar_nt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotImportNightHonda &raquo;</TD></TR><TR><TD CLASS="quote">Yeah that's what I figured but I know I'm not that big a stoner to connect the cables wrong. Where exactly is this fuse at?? In the box under the hood wright?? Thanks</TD></TR></TABLE>
yes. Under the lid there's a diagram that labels all of the fuses.
Old Oct 16, 2005 | 02:23 PM
Default Re: Battery Connected the wrong way. (transpar_nt)
Awesome it was the battery fuse....Thanks guys.
Old Dec 27, 2016 | 09:02 PM
tjbender's Avatar
Same thing with me only fixed the 100 amp fuse but there is no power to the rest of the fuse block. the 50 amp looks good. Any ideas?
Old Dec 28, 2016 | 04:14 AM
D16potato's Avatar
​​​​​​​thread is from 2005
Old May 22, 2023 | 05:10 PM
pjshipman's Avatar
I did this as well and it blew the main fuse, I replaced it and my audio fuse and now it won’t shift into park unless I manually bypass it. Any ideas? The Shift release system fuse is fine, so I’m guessing maybe the brake switch? Although I don’t hear anything from the solenoid when I depress the brake pedal either.
Old Oct 10, 2024 | 12:34 PM
AAlas's Avatar
Adrian
having the same issue, did you figure out why the shifter wouldn't come of park?
niceprelude
Sep 2, 2011 06:58 AM
Mychal71
Sep 10, 2006 02:01 PM
95civicSirCoupe
Sep 10, 2006 04:02 AM
FastHatch90
Apr 3, 2006 07:47 PM
Mr. Vapor
Jun 15, 2004 09:24 AM
