95 Civic with B18C1 OBD1 will not start tried everything!!!HELP
Old Oct 16, 2005 | 06:28 AM
b18civicgsr's Avatar
Default 95 Civic with B18C1 OBD1 will not start tried everything!!!HELP
Hey guys i have a 95 Civic With a GSR motor OBD1 and it will not start i have tried evrything. I have checked the entire wiring harness, bought a brand new distributor TWICE, Main relay, check all fuses , even tried a new ignition. I have also bought a new ECU. I am out of options can someone help me???
Old Oct 16, 2005 | 07:05 AM
Gamble-Did-it's Avatar
have you checked all of your grounding points? Make sure that you chevk your fuses in the engine bay as well
Old Oct 16, 2005 | 08:37 AM
hatchi's Avatar
Default Re: 95 Civic with B18C1 OBD1 will not start tried everything!!!HELP (b18civicgsr)
does it even crank?? check timing, wiring at the dist cap
Old Oct 16, 2005 | 09:18 AM
si0385.'s Avatar
pull a plug and lay it on a ground see if its got spark, if it does check to see if its got fuel pressure, if not <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamble &raquo;</TD></TR><TR><TD CLASS="quote">have you checked all of your grounding points? Make sure that you chevk your fuses in the engine bay as well</TD></TR></TABLE>
do that too
eghatch9295
Apr 28, 2011 05:26 PM
llozll
Mar 5, 2009 09:40 PM
slowslc
Jul 23, 2006 01:24 PM
b18civicgsr
Mar 9, 2005 10:01 PM
b18civicgsr
Feb 18, 2005 05:27 PM
