Is there a diff between an OBd0 and and OBd1 fuel rail?????crx LS/V-tec code 16 help
Old Oct 16, 2005 | 04:09 AM
1QuikSOHCZC's Avatar
Default Is there a diff between an OBd0 and and OBd1 fuel rail?????crx LS/V-tec code 16 help
my ls/v-tec is throwing a code 16 car was converted to obd1...no resisitor box...obd1 injectors...used same fuel rail as i did for my car when it was obd0? any help on how to get rid of code 16????
Old Oct 16, 2005 | 05:05 AM
Autoworks's Avatar
Default Re: Is there a diff between an OBd0 and and OBd1 fuel rail?????crx LS/V-tec code 16 help (1QuikSOHC)
I think the only diff in the rails are where the fpr is located. I am using a 95 GSR rail on mine with my AEBS. It just moved the fpr to the end instead of offset from the middle
Old Oct 16, 2005 | 03:55 PM
Default Re: Is there a diff between an OBd0 and and OBd1 fuel rail?????crx LS/V-tec code 16 help (Autoworks)
thanks....any guesses as to why im getting a code 16? im stumped... i took it to garage works out ihn palmdale and they couldnt figure it out.....ive checked all relays everything...
Old Oct 16, 2005 | 06:11 PM
TehMoonRulz's Avatar
CEL 16 is fuel injector, not rail, and I'm pretty sure you can't use your old non-obd injectors.
Old Oct 16, 2005 | 07:31 PM
Default Re: Is there a diff between an OBd0 and and OBd1 fuel rail?????crx LS/V-tec code 16 help (TehMoonRul
yea i know i cant use obd0 that why i have odb1 injectors.....i have checked everything thats why i am asking about the rail.......i know cel 16 is fuel injector.... but i have all 4 new obd1 injectors so u tell me whats wrong
Old Oct 16, 2005 | 07:54 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehMoonRulz &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure you can't use your old non-obd injectors. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QuikSOHC &raquo;</TD></TR><TR><TD CLASS="quote">yea i know i cant use obd0 that why i have odb1 injectors</TD></TR></TABLE>
o rly??
i've used obd2 injectors with a preobd pm6 and preobd injectors with an obd1 p28 w/o code 16.
The ecu doesn't care what kind of injectors you have. P&h injectors need a resistor box and saturated don't. Simple as that.
Have you verified voltage at the injectors, continuity from the red/blu/yel/brn wires to the ecu, ohmed out the injectors?
Old Oct 16, 2005 | 07:57 PM
i have tried everything...no resistor box ive even taken it to a well know shop out here and they couldnt fix it....so im stumped...car stilll runs good...but i hate having codes flashing
93LsVx
Aug 28, 2010 09:20 AM
98gsr-808-91dx
Mar 2, 2010 11:43 AM
adeline
Apr 11, 2005 07:13 PM
