p30 or p72 Ecu to run Ls vtec motor?
Old Oct 15, 2005 | 06:31 PM
Vtecme92's Avatar
Default p30 or p72 Ecu to run Ls vtec motor?
Ok I am debating on running a p30 (on the b16 obd1 motors) or p72 (obd1 gsrs) ecu on my setup ls/vtec b18b block with gsr head....what are the main differences and which one would your prefer any opinions would help...
Old Oct 15, 2005 | 06:34 PM
drdisco69's Avatar
Default Re: p30 or p72 Ecu to run Ls vtec motor? (Vtecme92)
If you're using the GS-R intake manifold, get the P72 to activate the throttle butterflies. Otherwise use either, and disable sensors as needed. You will (should) tune either ecu to get the most power out of the motor, and they're both pretty much the same, except for some minor differences like knock sensor, etc.
marcj
Apr 22, 2009 09:09 PM
marcj
Apr 19, 2009 11:40 AM
marcj
Apr 19, 2009 11:39 AM
Tsunami_racer
Aug 20, 2006 11:13 PM
Vtecme92
Oct 16, 2005 05:59 AM
