4-Wire to 5-Wire O2 Sensor (OBD1 VX ECU Pinouts?)...
Old Oct 15, 2005 | 02:09 PM
Sam1am26's Avatar
Default 4-Wire to 5-Wire O2 Sensor (OBD1 VX ECU Pinouts?)...
There are a million threads on how to switch from a 5-wire to 4-wire o2 sensor but not vice versa because everyone swaps different motors into a VX but not a VX motor into a different car... But I happened to have a 97 civic EX with with an OBD2->OBD1 harness and a 93 OBD2 VX motor/ecu... So the wiring harness has 4 wires and the o2 sensor has 5 and the ecu is looking for five... So, basically all I need to know is what are the 5 pins on the OBD1 VX ECU for the O2 sensor and the corresponding wire colors from the O2 sensor... I looked at some FAQ and I have found the pinouts for the 92-95 ecu but I can't identify all 5 pins.... If anyone can help that would be greatly appreciated...
Old Oct 16, 2005 | 08:46 AM
Sam1am26's Avatar
Default Re: 4-Wire to 5-Wire O2 Sensor (OBD1 VX ECU Pinouts?)... (Sam1am26)
Bump... no 5-Wire O2 Sensor gurus?
Old Oct 18, 2005 | 01:45 PM
Sam1am26's Avatar
Default Re: 4-Wire to 5-Wire O2 Sensor (Sam1am26)
So nobody knows or knows where I can find the answer?.. I've tried searching H-T but it's hard when you can't search for two letter words...
turbo sol
Sep 4, 2008 05:19 PM
dturbo
Jun 8, 2005 06:16 PM
trooper0641
Jul 3, 2003 04:57 PM
bdicustoms
May 27, 2003 06:30 PM
