Knocking sound at take off.
I have this lil knocking noise now coming from my front passenger side.. i only hear it at take off from a stop. Was wondering if it's my tie rod that needs replacing and could an unbalanced wheel be the cause of this...
99 accord lx
thanks
99 accord lx
thanks
I'm going to need a little furthur info in order to help.
Is this a one-time knock as you take off?
Does it do it more when you're turning or going straight?
Does it do it while in neutral/park or only while moving?
Does it do it over rough roads or all the time?
There are several things engine/trans/suspension that can cause a knock. Any additional info can help allow me to pin it down for you
P
P
it does it everytime i take off from a stop. i dont hear it going over bumps or turning in either direction. And i drive on asphalt 99% of the time.. but here in quebec, it's pothole ridden
The only things that immediately come to mind....
Loose brake pad in the r/h caliper
Loose r/h motor mount
Movement in the lower control arm bushings.
This may turn out to be a rather drawn out process, 'cuz really I've been more successful using the "touching, banging and prying" method to find noises. I'll help as best I can from here, ... hope we're lucky
P
P
Fernandos_EJ8
Dec 19, 2019 05:35 AM
DKay
Sep 30, 2016 10:19 PM
c.brummett
Apr 29, 2016 06:25 PM
CimorelliCRX
14
Jan 25, 2003 07:54 PM
