1990 civic si leakin from sunroof
Hi,
I suspect my si 's drain holes are clogged in the rear.
Is the only way to get to them, to take the sunroof off?
Anyone have an tricks?
Hank
Hank
jw how is the rubber around the sunroof, i know mine didnt seal in the back, and my drain tube was cloged, in crxs the tube is in the drivers side rear, you have to pull the rear interior panel. but im not sure if its the same for civics
The car is a hatchback.
I think there are drains on each corner of the sunroof pan.
The car was parked with the front elevated on a hill. I suspect the back
drains are clogged?
Im able to get to the front drains. Ill park with the rear elevated
for now.
Hank
drains are clogged?
for now.
Hank
my 90Si hatch leaked for the first time the other day, it was parked at a slight incline and had heavy rain for hours and hours. It has rained since but I've either been on level ground or facing downward, and havent had any issues since that one day.
Turbo Dan
Jun 25, 2011 11:27 AM
crx_ef8
Dec 31, 2002 07:00 PM
