NEED HELP with eg sway bar install???
need your help guys...just picked up a swaybar from this guy who said it's a stock eg si hatch front lower swaybar....however i think i got scamed...i don't see where possibly the end links bolt on to? so my buddy with his 1990 DA came by and his teg is equiped with a stock front sway bar which looks identical to mine and i noticed his lower control arms are diffent and where the end links bolt on to my control arms don't have it?........sorry for the long question....if u guys have any suggestions or ideas or even pictures of what the sway bar looks like on an eg hatch installed i would apreaciate it..thnks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsir01 »</TD></TR><TR><TD CLASS="quote">need your help guys...just picked up a swaybar from this guy who said it's a stock eg si hatch front lower swaybar....however i think i got scamed...i don't see where possibly the end links bolt on to? so my buddy with his 1990 DA came by and his teg is equiped with a stock front sway bar which looks identical to mine and i noticed his lower control arms are diffent and where the end links bolt on to my control arms don't have it?........sorry for the long question....if u guys have any suggestions or ideas or even pictures of what the sway bar looks like on an eg hatch installed i would apreaciate it..thnks</TD></TR></TABLE>
does your front sway bar look like mine in my sig?? look at my endlink hole. is your the same vertical hole? meaning the endlinks go through the side of the sway bar? or are you endlink holes flat, and the bolt goes down into it? you can fit any year integra sway bar on your civic if you have the corresponding endlinks. there are two versions of endlinks. but you need to check your front lca's and see if there is a hole... my cx hatch had the holes so i can only assume yours does too since the cx is the lowest trim level... you maybe looking at the wrong part of the lca aswell... show us a photo of your front lca from the bottom up (not from the side)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">
does your front sway bar look like mine in my sig?? look at my endlink hole. is your the same vertical hole? meaning the endlinks go through the side of the sway bar? or are you endlink holes flat, and the bolt goes down into it? you can fit any year integra sway bar on your civic if you have the corresponding endlinks. there are two versions of endlinks. but you need to check your front lca's and see if there is a hole... my cx hatch had the holes so i can only assume yours does too since the cx is the lowest trim level... you maybe looking at the wrong part of the lca aswell... show us a photo of your front lca from the bottom up (not from the side)</TD></TR></TABLE>
hey, thanks for the response, ok i took a look at your swaybar in your sig and your endlink holes are different than mine, mines are flat...and i don't see a hole on my lower arm where it could bolt on to?...i will try to get a picture of the underside of my lca...
You need the front LCA's that came off any civic integra that came with stock front swaybars...i.e. Civic EX, Civic Si, Del Sol Si, all integras. That's your answer!
o2flow.net
11
Jul 12, 2006 11:32 AM
spoon95eg
Suspension & Brakes
Apr 11, 2006 09:14 PM
pynikal
Feb 16, 2006 05:31 PM
