boosted d16z6 overheats
Old Oct 15, 2005 | 09:49 AM
slammed_coupe's Avatar
Default boosted d16z6 overheats
hey my problem is that when i boost my overflow tank spills out coolant everywhere in my engine bay...i did a compression test and i get 225 accross the board but i thought it might still be my head gasket so i changed it and still the same thing...then i took my thermostat off and tried it with that still no luck
Old Oct 15, 2005 | 09:52 AM
coquitlamEG's Avatar
are you using your stock radiator? Sometimes they can't handle the extra heat. Ever thought of upgrading to an aluminum rad?
Old Oct 15, 2005 | 10:27 AM
bmw626's Avatar
Default Re: (coquitlamEG)
Koyo or Fluidyne
Old Oct 15, 2005 | 10:35 AM
Default Re: boosted d16z6 overheats (slammed_coupe)
2 other friends have the same setup and they are running a stock rad and they are fine...why is mine doing this...i just started boosting last week on 7psi and it's pretty bad
Old Oct 15, 2005 | 10:57 AM
anyone?
Old Oct 15, 2005 | 11:00 AM
komat's Avatar
your head could be lifting
Old Oct 15, 2005 | 11:03 AM
on 7pounds? that and i torqued my head studs at 5 pounds extra just in case
Old Oct 15, 2005 | 04:11 PM
komat's Avatar
did you reuse your stock head bolts??
if so thats the reason
get apr
Old Oct 15, 2005 | 05:02 PM
have you checked your fan to make sure it's kicking in when needed?
Old Oct 15, 2005 | 06:33 PM
clarkekent13's Avatar
if the above to posts dont solve your problem - get a new radiator- stock ones maybe work fine if in good condition, but yours probably just isnt up to par. Especially if previous owners got happy with their local Autozone "radiator stopleak", as I found out when I redid my cooling system. You could go fluidyne or something- but I got one of these, and I've been rocking cool temps for over a year now on my b16-
http://cgi.ebay.com/ebaymotors...QrdZ1
IMHO,get one of those and drain /flush your block completely (undo the drain bolt in your block, usually right below your exhaust manifold)
Old Oct 15, 2005 | 06:43 PM
LilCivic04's Avatar
Default Re: (clarkekent13)
dude you have a blown head gasket, its the worst that could happen. i had the same problem few weeks ago and it keep on overfilling. so i changed it out and still it didn't work. i also changed thermostat, radiator cap and i have a new del sol radiator. i got 185 across the board w/ compression it that didn't tell me very much either.
Old Oct 15, 2005 | 06:44 PM
civic_driver's Avatar
what fan do you use with that radiator? Do you use stock fan (can it even fit?) or the thin fans they sell?
Thanks!
Old Oct 15, 2005 | 08:19 PM
Orangedragone's Avatar
radiator cap? stoopid as it may seem, but it's a cheap thing you could check.
amazingly enough it's recommened you change radiator caps once a year. most of the time nothing goes wrong, but there are those few exceptions where the cap goes bad, and yeah.
my friends 240 was an exception and costed him two motors.
Old Oct 15, 2005 | 08:24 PM
specv5150's Avatar
Default Re: boosted d16z6 overheats (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote"> your head could be lifting</TD></TR></TABLE>
my vote. I thought the EXACT same thing. Blown headgasket. Went out bought a new HG, the old one was perfect. I was running 7psi as well
Old Oct 15, 2005 | 08:31 PM
mike93eh
Guest
Posts: n/a
your head is lifting.
get some arp studs, oem headgasket, and copper spray.. youll be golden then.
hell this is like a golden rule to boosting honda engines...
Old Oct 15, 2005 | 08:33 PM
Street Ghost's Avatar
Default Re: boosted d16z6 overheats (specv5150)
most likely.. your head is lifting... time for new HG, arp studs, and resurface the head
same thing happened to me at 7psi but the coolant never made its way out the overflow container and it never overheated.
Old Oct 16, 2005 | 06:49 AM
Default Re: boosted d16z6 overheats (Street Ghost)
like i said i changed my HG still nothing
changed:
-rad cap
-head gasket
-head bolts (stock not arp)
-copper sealant
-thermostat
-burped my coolant system
Old Oct 16, 2005 | 08:10 AM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_coupe &raquo;</TD></TR><TR><TD CLASS="quote">like i said i changed my HG still nothing
changed:
-rad cap
-head gasket
-copper sealant
-thermostat
-burped my coolant system</TD></TR></TABLE>
well, theres your problem. stock head bolts STRETCH!!!!!!!!!!!!!!!!! they cause your head to lift and then leak. did you not read my post?
Old Oct 16, 2005 | 08:13 AM
Default Re: boosted d16z6 overheats (mike93eh)
dude it's in the changed items list...i put new ones
Old Oct 16, 2005 | 08:18 AM
.Grimace's Avatar
footwork mastery
he is saying new stocks ones aren't good enough. you need to get new arp ones
Old Oct 16, 2005 | 10:26 AM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_coupe &raquo;</TD></TR><TR><TD CLASS="quote">dude it's in the changed items list...i put new ones</TD></TR></TABLE>
DUDE!!!!!!!
look at the part i bolded! STOCK you put STOCK headbolts in there, new or not they are junk and will stretch. you need ARP head studs.
best place to get them is here...
http://shopping.lightningmotor...t=227
Old Oct 16, 2005 | 02:34 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">DUDE!!!!!!!
http://shopping.lightningmotor...t=227</TD></TR></TABLE>
Sometimes I wonder why bother if people arent even going to listen to or read what you write. Does it really take 4 people to say this before people will get a clue....
Old Oct 16, 2005 | 03:00 PM
HabitualOffender's Avatar
Ahem... Stock...
Did it come stock turbo'd?
No.
Why put stock back on? Common sense...
Old Oct 16, 2005 | 03:48 PM
dewoine's Avatar
Default Re: boosted d16z6 overheats (HabitualOffender)
have you checked your fan to make sure its clicking on...plus theres alot of boosted cars runnin stock new studs doesnt mean thats they dont hold up.
Old Oct 16, 2005 | 03:50 PM
specv5150's Avatar
Default Re: boosted d16z6 overheats (dewoine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dewoine &raquo;</TD></TR><TR><TD CLASS="quote">have you checked your fan to make sure its clicking on...plus theres alot of boosted cars runnin stock new studs doesnt mean thats they dont hold up.</TD></TR></TABLE>
Yeah well he just changed all that crap and still overheats and you have popel who have chimed in with their experinces so.....
