is my head gasket blown? compression: 166 165 164 165, white smoke from exhaust
Old Oct 15, 2005 | 09:33 AM
sidewayz32's Avatar
Default is my head gasket blown? compression: 166 165 164 165, white smoke from exhaust
90 crx si (d16a6)
blows white (blueish) smoke from the exhaust. sometimes alot and sometime not much at all. the car has died on me twice recently. after it dies, it won't start for about 20 min. after it starts is when it blows ALOT of smoke. then the next day it will barely blow any.
i just did a compression check and the numbers (166, 165, 164, 165) seem to be good.
what else should i check to see if its the head gasket?
or am i totally wrong thinking head gasket? is it something else?
Old Oct 15, 2005 | 10:10 AM
crx_88_si's Avatar
do you have to add coolant at all? have you checked the coolant level.
Old Oct 15, 2005 | 10:51 AM
sidewayz32's Avatar
Default Re: (crx_88_si)
i stopped driving it when this started, so it hasn't really had a chance to burn enough coolant (if thats what the problem is) to be noticeable in the overflow tank.
Old Oct 15, 2005 | 03:50 PM
virginia_dude's Avatar
Default Re: is my head gasket blown? compression: 166 165 164 165, white smoke from exhaust (sidewayz32)
blueish smoke is oil....
when its doing this does the smoke smell sweet....antifreeze in the exhaust has a very pronounced and distinctive odor to it.
Old Oct 16, 2005 | 11:27 AM
sidewayz32's Avatar
i dunno about smelling sweet, but it definately isn't oil. i know what that smells like when burning.
Old Oct 16, 2005 | 02:19 PM
erebunicrx's Avatar
usually when theres a blown headgasket theres 2 cyl's that are right next to each other that read alot lower then the rest.
20mph
Sep 30, 2015 07:42 PM
mannydhanju
Feb 21, 2009 09:33 PM
the_dxB16
Dec 25, 2008 01:23 PM
BrokenRex
Dec 24, 2005 04:54 PM
youngkow
Dec 27, 2003 12:18 PM
