Apexi N1 Suspension Question
Has anyone heard of the 99Spec N1s with the silver pillow mount which is supposed to be dome shaped? Are there advantages over the red pillow mounts? Also, is there any wrench needed to adjust the height of the coilovers?
I have the upgraded "tapered" pillow mounts. they are dome shaped... tapered.
The advantage of it is so that it does not tear up your shock tower like the stock hats that come w/ the n1 susp. and yes, you do need the spanning wrenches to adjust the height, im in the process of ordering some from inlinefour.com right now. you can also prob use universal snap-on wrenches.
Thanks for the info. Does it come with a wrench to adjust the height?
raresi99
Mar 13, 2007 05:37 PM
