G3 White Gauge cluster bulbs
Hey guys, i'm trying to change my cluster on 00 Integra to be white instead of the greenish look it has when stock.
From what I found out, the bulb size is 194. I can either get regular 194 or LEDs 194. However, I heard that the LED will not put as much output, but I have no idea.
Some said that i won't get much light since the G3 clusters only have 3 bulbs.
Does anyone have any experiences?
I want mine to kind of look like this in my friend's TC. Just the light output that is:
His used to look like this at first then he put LED bulbs:
Thanks for any help
Thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangebarius »</TD></TR><TR><TD CLASS="quote">the bulbs have a little blue rubber sock over them. take off this sock and it will be whiter.</TD></TR></TABLE>
oh ok, i'll try that, but i dont know, i have a feeling i won't get anything close results to the picture above.
integra gauge will never light up like lexus or benze. such as......
led's will only make one stop super bright.
194 bulb will not light up super brignt but good enough. (blue color will light up less, orange or red or amber will be brighter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m2slsvtec »</TD></TR><TR><TD CLASS="quote">use the super white bulbs.... the peanut bulbs.. hahhaa just change all three to the super white bulbs.
so are those the same as 194 LEDs bulbs or are you talking about something else?
</TD></TR></TABLE>so are those the same as 194 LEDs bulbs or are you talking about something else?
Well from my own personal experience, when i took off my rubber condom off the stock ones , it turned kind of peachy. Then i went on to http://www.superbrightleds.com and i got some white leds from there, it was OK , it doesn;t dispurse light as well as a filiment bulb. So for my opionion, use hyper white Polarg bulbs to get the most white and dispursement
I found some 194 Amber bulbs at a local Kragen. They light up the cluster just as well as the stock bulbs did. I'm not sure if you could find any white ones, though, as the bulbs were designed for turn signals.
Hiroshima_VTi-S
Jul 31, 2007 04:49 PM
x95DC2
May 10, 2007 04:32 PM
