dislocated the axles, help!!!!!
Old Oct 14, 2005 | 10:08 PM
track_assassin's Avatar
Default dislocated bearings in the axles, help!!!!!
sorry if this has been asked but i did try to find it and ended up with no luck.
here is the situation, pulled driver axle out of a teg. dislocated the bearing or what ever is inside the boot (not the cv boot but the other one). can that be repaired? if yes, how hard is it / or how much will it cost to repair?
Old Oct 15, 2005 | 03:52 AM
come on guys, some one help me out
Old Oct 15, 2005 | 05:32 AM
ne3ek's Avatar
Default Re: (track_assassin)
did you rip the boot? If you didn't you can push it back in you just have to find the right spot and it should push right back in.
Old Oct 15, 2005 | 07:18 PM
A1's Avatar
A1
Default Re: (ne3ek)
its hard to put it back w/out opening the boot.
Old Oct 15, 2005 | 07:23 PM
dognutz's Avatar
Default Re: (d16why8)
Sometimes you can fit it back together sometimes you can't. Try to tap it together. One end on the cement and tap the other side with a hammer. Either way it's like 70 to 100 bucks for a new axle.
Old Oct 15, 2005 | 07:51 PM
naw, i couldnt fix it. but thanks for the info. i guess i will just have to buy a new one. damm
waid786
Apr 19, 2012 07:03 AM
Randysi
13
Jun 29, 2011 07:58 PM
TeGGY_LS
Jun 15, 2004 12:29 PM
youngvedder
May 30, 2004 02:01 PM
Kazmans94cord
Mar 31, 2002 06:49 PM
