trouble P0141? Help
Old Oct 14, 2005 | 09:02 PM
antonio_pr2003's Avatar
Default trouble P0141? Help
i have a 98 civic dx and the check engine light came on the trouble is
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) ?
what that mean the O2 sensor or a heater sensor
Old Oct 14, 2005 | 09:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: trouble P0141? Help (antonio_pr2003)
for oxygen sensors to work properly they need to have a constant temp. thats why they have an internal heater. the code is for a heater circuit malfunction. basically, what usually happens, is the heater burns out in time causing an open in the circuit. when this happens, the ecu looks for a voltage drop saying that the heater is using the voltage. if it isnt, the ecu knows there is a problem with the heater. you can ohm the heater circuit in the sensor, but i am about 99% sure replacing bank 1 sensor 2 oxygen sensor will fix it.
the bank 1 sensor 2 is the sensor after the cat.
papi123
Honda Civic (2001 - 2005)
Apr 25, 2014 09:07 PM
craigmack14
Nov 2, 2009 05:08 PM
Perfectionist
Oct 20, 2006 03:36 PM
CereaLand
Jun 30, 2004 12:01 PM
boostmywankle
Apr 28, 2004 03:50 AM
