Swaybar Bracket Question
Hey,
I know that the sizes of the front bars were either 18 or 19m, for ef civics. Just wondering if anybody knows if both brackets,are the same for the 18 and 19mm bars.
ok I'm talking about the front swaybar... which models had just the 18mm swaybar, and are the brackets that hold the bushings to the chasis the same on those as the ones with 19mm swaybars?
the U shaped metal bracket is the same. the bushings are different for the 18mm and 19mm swaybars.
btw, all DX and Si CRX front swaybars are 18mm, all years. sedans and wagons are 19mm. HF is 17.3mm, hollow.
DA integra bars are 23mm, hollow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">the U shaped metal bracket is the same. the bushings are different for the 18mm and 19mm swaybars.
DA integra bars are 23mm, hollow.</TD></TR></TABLE>
perfect. thanks!
perfect. thanks!
OUT OF ORDER ROB
Jun 14, 2006 11:51 PM
