can you lower car with just koni shocks ?
I'm just curious because I heard theres something you can adjust on the shock that can go up and down. I'm probably hearing it all wrong, but can someone just fill me in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin716 »</TD></TR><TR><TD CLASS="quote">no you will need coilover sleeves or lowering springs. </TD></TR></TABLE>
^what he said...the adjusting for koni shocks is just to adjust how stiff the shock you want it to be
I know on the koni yellow sport shocks there are three perches, so you should be able to set it on the lowest perch, but it wouldn't be a significant drop.
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">I know on the koni yellow sport shocks there are three perches, so you should be able to set it on the lowest perch, but it wouldn't be a significant drop.
Ali</TD></TR></TABLE>
yup. i've never heard of anyone lowering their car this way, but it is possible.
after spending 400+ on shocks, why not just throw in another 150 and get a set of springs? it's not any extra work or anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper »</TD></TR><TR><TD CLASS="quote">
after spending 400+ on shocks, why not just throw in another 150 and get a set of springs? it's not any extra work or anything.</TD></TR></TABLE>
its true or just get some ground control coilovers. Adjustable ride height and custom spring rates. You can't go wrong, great for daily driving (if you don't mind having a little bit of a stiff ride) and supposedly good for track usage to.
And you might as well go both anyway cause installing the shocks requires removal of your springs.
Ali
Ali
