b17 or b20?
Old Oct 14, 2005 | 01:22 PM
DA-9mordef's Avatar
Default b17 or b20?
my friend is offering to trade his b17 for my b20a im going all motor i want at least low 14s in my da what would you do ????
Old Oct 14, 2005 | 01:39 PM
98 Spec R's Avatar
Default Re: b17 or b20? (DA-9mordef)
I would buy a VTEC head for your B20 and not trade.
Old Oct 14, 2005 | 01:47 PM
bottlefed13's Avatar
Default Re: b17 or b20? (98 Spec R)
QUOTE=98 Spec R]I would buy a VTEC head for your B20 and not trade. [/QUOTE]
Old Oct 14, 2005 | 01:59 PM
BrooX's Avatar
screw his b17. Why do you think he wants your b20? Because he will probably get a b16 head, smoke you with the b17 you have and call it a day. You should think like your friend, and keep what you got and build that motor.
Old Oct 14, 2005 | 02:58 PM
nickG's Avatar
keep your motor...buy the head from your friend....then he wont have a motor and youll smoke him all the time....
Old Oct 14, 2005 | 03:16 PM
Kendall's Avatar
You people seem to have missed the most important part of this whole ordeal. the B20A is from an old school prelude and is absolutely worthless. Anyone offered a B17 for one should not think twice about it.
If you decide not to trade, tell him I'll give him two B20A's for it.
Old Oct 14, 2005 | 06:23 PM
nickG's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You people seem to have missed the most important part of this whole ordeal. the B20A is from an old school prelude and is absolutely worthless. Anyone offered a B17 for one should not think twice about it.
****..i totally missed that...if you have a b20a get rid of it quick....but if its a b20b or b20z keep it...
reading comprehension&gt;me
Old Oct 14, 2005 | 08:05 PM
Rajin's Avatar
Default Re: (nickG)
b17 &gt; b20a's
Old Oct 14, 2005 | 08:12 PM
JDMorgan's Avatar
Default Re: (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">b17 &gt; b20a's</TD></TR></TABLE>
noo more like...... anything &gt; b20a
Old Oct 14, 2005 | 08:13 PM
Rajin's Avatar
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">
noo more like...... anything &gt; b20a</TD></TR></TABLE>
True
my feet &gt; b20as
Old Oct 15, 2005 | 04:41 AM
LSracing94's Avatar
Default Re: (Rajin)
why is the b20a so bad, just wondering
Old Oct 15, 2005 | 04:57 AM
gsrvtec2's Avatar
Default Re: (LSracing94)
no vtec
Old Oct 15, 2005 | 06:59 AM
nickG's Avatar
Default Re: (tekneshum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekneshum &raquo;</TD></TR><TR><TD CLASS="quote">no vtec</TD></TR></TABLE>
no...
search for b20a and read about it...
from like 10 mins of reading, the b20a block will NOT accept a bseries vtec head, and due to its large stroke, has a terrible r/s ratio and cannot be safely revved high.
but the crank can be used as an oem stroker in a b18a or b, using the same rods/pistons...
but im not 100% sure about anything i just said so correct me if im wrong, or do you own research to prove me wrong...
Old Oct 15, 2005 | 09:16 AM
DAcraze's Avatar
Default Re: (Rajin)
i agree
Old Oct 15, 2005 | 09:22 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">noo more like...... anything &gt; b20a</TD></TR></TABLE>
I disagree.
B20A &gt; B21A
Old Oct 15, 2005 | 09:49 AM
projectTeG's Avatar
no its just a poorly designed b-series....alot of the parts are not interchangable....they mount like a h and a f series..they have the (ahhh forgot the name) sleeves that wear rings out fast. just because a engine doent have vtec...doesnt mean its bad. BTW trade it for the b17..its a good motor....also rare. id love to get one if i could
Old Oct 15, 2005 | 09:50 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
nope. 98hp a20a&lt;b20a
Old Oct 15, 2005 | 10:09 AM
Default Re: (Palmy Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">
just go buy a b16 they are pretty much the same thing, same hp and tq numbers</TD></TR></TABLE>
117 lb ft. &gt; 111 lb ft.
only the b16b can match the b17s 117 ft lbs of torque.
Old Oct 15, 2005 | 03:02 PM
integ gsr 92's Avatar
til ur friend ill buy his b17a long block .. leave me ur # or ur friends #
Old Oct 15, 2005 | 03:28 PM
fullracecrxsi87's Avatar
even if it was a crv b20 id pic the b17
Old Oct 15, 2005 | 03:37 PM
Kendall's Avatar
Default Re: (dab16integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dab16integra &raquo;</TD></TR><TR><TD CLASS="quote">even if it was a crv b20 id pic the b17</TD></TR></TABLE>
Amen.
Then I'd find a B16 shortblock, and use the B17 rotating assembly and head with the PR3 pistons in the B16 block with some CTR cams and an ITR intake manifold. Throw on a good header and you'll have one hell of a sleeper.
Old Oct 15, 2005 | 07:49 PM
12secteg's Avatar
Yeah get that B17 and ditch the B20. CRVTEC AKA b20 w/vtec are not dependable set ups because the B20 blocks cannot revv as high and have a horrible rod to stroke ratio not to mention have very weak cylinder walls. Like most everyone on here's been saying the B17's are hella rare and are very desired, go with that set up, just put some ITR pistons in if you get a chance to up the compression.
Old Oct 15, 2005 | 08:16 PM
JDMorgan's Avatar
Default Re: (nickG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG &raquo;</TD></TR><TR><TD CLASS="quote">from like 10 mins of reading, the b20a block will NOT accept a bseries vtec head, and due to its large stroke, has a terrible r/s ratio and cannot be safely revved high.
but the crank can be used as an oem stroker in a b18a or b, using the same rods/pistons...</TD></TR></TABLE>
pretty sure you have to mod it somehow. i read once they use b18c cranks to make more reliable when reving high and making good hp. they were modifying either the crank or mains, i forget which.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Then I'd find a B16 shortblock, and use the B17 rotating assembly and head with the PR3 pistons in the B16 block with some CTR cams and an ITR intake manifold. Throw on a good header and you'll have one hell of a sleeper.</TD></TR></TABLE>
i got a b16a block, gsr girdle and mains, b17 rotating assembly, and brand new swain coated usdm itr pistons, if you wanna be mr. sleeper?
Old Oct 16, 2005 | 06:10 AM
LSracing94's Avatar
Default Re: b17 or b20? (12secteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12secteg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah get that B17 and ditch the B20. CRVTEC AKA b20 w/vtec are not dependable set ups because the B20 blocks cannot revv as high and have a horrible rod to stroke ratio not to mention have very weak cylinder walls. Like most everyone on here's been saying the B17's are hella rare and are very desired, go with that set up, just put some ITR pistons in if you get a chance to up the compression.</TD></TR></TABLE>
false, i brought my b20vtec to 9000 rpm all day long
Old Oct 16, 2005 | 11:11 AM
apok's Avatar
Default Re: b17 or b20? (LSracing94)
Actually, its quite true that the casting process weakened the cylinder walls between cylinders in most B20 blocks. It was luck that you were able to bring a B20VTEC to 9000 more than maybe a few times without the rod bolts being destroyed and a piston or two flying through the engine or grinding down the cylinder wall because of the lack of oil in a stock non-VTEC car's design.
There's a reason why Honda designed VTEC engines with oil squirters. It was to keep piston temperatures down and to keep the cylinder walls well lubricated. Also, VTEC engines require more oil than non-VTEC engines. There's much more to building a reliable engine than slapping a VTEC head on a B18/20 or H23 and calling it a day while revving way past the designed redline.
