Suspension & Brakes Theory, alignment, spring rates....
Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR?
Old Oct 14, 2005 | 12:05 PM
Kapolei INTEGRA's Avatar
Default Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR?
Yep. Done a search so far there are no topics covering that issue. So yea I'm flame-proof. Anyway, as topic says: Will Koni Yellows from 98-00 Civic fit on 94-01 Integra LS/GSR?
There was an old post of someone saying that the rear fork will be a little wider on the LCA, that is if you were to fit Integra shocks onto the Civic LCA and then run washers for fitment.
Old Oct 14, 2005 | 12:12 PM
CRX Lee's Avatar
Default Re: Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR? (Kapolei INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kapolei INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">Yep. Done a search so far there are no topics covering that issue. So yea I'm flame-proof. Anyway, as topic says: Will Koni Yellows from 98-00 Civic fit on 94-01 Integra LS/GSR?
The front shocks are the same but the 96-00 car has a narrower lower and deeper clevice on the rear because the LCA has a shorter steel bushing in the rubber mount. You cannot install that shock on the rear of the Integra unless you were to grind your sleeve shorter or replace the entire rubber and steel bushing from the later car. Valving and spring perch are the same.
Old Oct 14, 2005 | 05:34 PM
Default Re: Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR? (CRX Lee)
thanks so much man! aww damn came to expected it somehow
Old Oct 27, 2005 | 09:23 PM
TheBobFather's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee &raquo;</TD></TR><TR><TD CLASS="quote">The front shocks are the same but the 96-00 car has a narrower lower and deeper clevice on the rear because the LCA has a shorter steel bushing in the rubber mount. You cannot install that shock on the rear of the Integra unless you were to grind your sleeve shorter or replace the entire rubber and steel bushing from the later car. Valving and spring perch are the same. </TD></TR></TABLE>
If this is true than why are the part #'s the same at Tokico...........do the after market shocks differ from company to company???
http://www.tokicogasshocks.com/car/appresults.asp
Old Oct 27, 2005 | 09:39 PM
Default Re: Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR? (jnbhonda)
hmmm can anyone else explain?? is it true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnbhonda &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.tokicogasshocks.com/car/appresults.asp</TD></TR></TABLE>
Old Oct 28, 2005 | 12:26 AM
chrisw85's Avatar
The rear LCA shock bushing on the EG is wider than on the EK.
So, what some companies do instead of making two different width lower forks, is just to include washers or spacers for the EK chassis.
Old Oct 28, 2005 | 05:41 AM
CRX Lee's Avatar
Koni, Bilstein, KYB, and obviously OE Honda make different parts for the rear of the two cars based on proper fitment for the rear lower control arms. Tokico does not so they must provide some spacers or washers. They do this also for a Mustang front strut that changed in the mid-'80s when everyone else makes a different part.
Tokico uses the wider fork with the some kind of spacers. Since you have Konis that have the right fork for the '96-00 LCA, it is already too narrow for the '92-95 Civic/'94-01 Integra. You can put the wider on on the narrower arm if you have spacers and keep it tight so the bolt does not bend) but you can't put the narrower fork on the wider bushed arm.
Old Oct 28, 2005 | 08:35 AM
So simply put, the front/rear springs WILL work. The front shocks WILL work also. But the rear shocks from a 00 civic WILL NOT fit the DC
Old Oct 29, 2005 | 05:45 PM
t0ekn3e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnbhonda &raquo;</TD></TR><TR><TD CLASS="quote">So simply put, the front/rear springs WILL work. The front shocks WILL work also. But the rear shocks from a 00 civic WILL NOT fit the DC</TD></TR></TABLE>
correct, unless you want to grind down your lca.
Old Dec 14, 2005 | 11:20 AM
97civic123's Avatar
Default Re: Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR? (t0ekn3e)
so the vis versa,(for the rears) a 94-00 integra shocks WILL work on a 96-00 Civic???? with washers? how about without?
Old Dec 14, 2005 | 11:32 AM
CRX Lee's Avatar
Default Re: Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR? (97civic123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic123 &raquo;</TD></TR><TR><TD CLASS="quote">so the vis versa,(for the rears) a 94-00 integra shocks WILL work on a 96-00 Civic???? with washers? </TD></TR></TABLE>
Not recommended as proper but you can do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic123 &raquo;</TD></TR><TR><TD CLASS="quote"> how about without?</TD></TR></TABLE>
No, you will bend and damage things.
98GSRDC2
Suspension & Brakes
Feb 22, 2007 02:55 PM
Elemental
Jul 17, 2004 05:44 AM
xdavidx
Mar 4, 2004 10:40 AM
Alexander
Sep 18, 2003 06:01 PM
216.226.142.95:27016
Sep 6, 2003 06:12 PM
