Question, regauding coolant/fittings.. Barb to AN
Old Oct 14, 2005 | 08:55 AM
done's Avatar
Default Question, regauding coolant/fittings.. Barb to AN
The coolant line running to the manifold, that fitting can be swapped out.
Is it possible to change any of the lines on the actual coolant neck? or even on the throttle body. Will those barbs back out??
edit: Trying to run coolant lines to my turdblower.
Came up with a better idea, might be easier just to "tee" back into the out line from the throttle body..
edit, pictures are worth 1000 words..
Modified by Jordo@KAP at 12:09 PM 10/14/2005
Old Oct 14, 2005 | 09:52 AM
Chris F's Avatar
Default Re: Question, regauding coolant/fittings.. Barb to AN (Jordo@KAP)
Not sure I'd suggest it, but I have 2 fittings welded on my radiator (top and bottom) that are connected to the turbo.
good luck with it
Old Oct 14, 2005 | 12:13 PM
done's Avatar
Default Re: Question, regauding coolant/fittings.. Barb to AN (Chris F)
yeah i figured it out without having to drill or weld..
it should work, in theory..
Junesong
Feb 5, 2009 09:52 AM
done
Oct 14, 2005 12:24 PM
nekkedR
Jan 14, 2004 01:19 PM
GruvyTune
Sep 6, 2002 05:09 AM
Floyd91
Jul 25, 2001 06:32 PM
