What size slicks for b16 crx?
Old Oct 14, 2005 | 07:26 AM
senate33's Avatar
Default What size slicks for b16 crx?
Exactly what the title says, what size slicks would you reccomend for a b16 crx and i will probably go nitrous soon too. thanks for the help.
Old Oct 14, 2005 | 07:32 AM
hondaguyef's Avatar
Default Re: What size slicks for b16 crx? (senate33)
M/T 20x8x14. They'll work w/ the nitrous as well (depending on shot size). If over 50 I'd maybe switch to some 22's.
Phil
Old Oct 14, 2005 | 07:34 AM
DaveF's Avatar
Default Re: What size slicks for b16 crx? (hondaguyef)
lol. we got a crx spraying an 80 shot on a ls/vtec ran 11.50@115 on 24.5's with a ls trans.
Old Oct 14, 2005 | 07:40 AM
hondaguyef's Avatar
Default Re: What size slicks for b16 crx? (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">lol. we got a crx spraying an 80 shot on a ls/vtec ran 11.50@115 on 24.5's with a ls trans.</TD></TR></TABLE>
That's all in the driving right there though. He seems to be new to the game so, the 20's will be optimum for him at stock power level and a lil' above.
Old Oct 14, 2005 | 07:45 AM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senate33 &raquo;</TD></TR><TR><TD CLASS="quote">Exactly what the title says, what size slicks would you reccomend for a b16 crx and i will probably go nitrous soon too. thanks for the help. </TD></TR></TABLE>
Hi senate33:
Are you Allmotor.
Are you Turbo.
What is your HP.
Are you a full race car.
Are you a street car.
Are you wheelie bar.
Are you going to be on nitrous all the time or some times, because that will change your slick sizes.
This is info that we all need to know to help you out on what sizes slicks you need.
Good Luck senate33 and be SAFE in the 2005-06 racing season.
John@M&H
Old Oct 14, 2005 | 08:25 AM
senate33's Avatar
Default Re: What size slicks for b16 crx? (SlicksMH)
wow thanks guys, im not too new but im new to the track, its a street car for sure, right now it b16, type r cams, lsd, i/h/e, some basics, later on i plan on running probably 100 shot with built block so thats the setup
Old Oct 14, 2005 | 12:07 PM
senate33's Avatar
will 8/22-13 m and h slicks fit stock honda steelies?
Old Oct 14, 2005 | 12:14 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senate33 &raquo;</TD></TR><TR><TD CLASS="quote">will 8/22-13 m and h slicks fit stock honda steelies?</TD></TR></TABLE>
i dont think that would be a good idea, when you put a wide slick on a skinny wheel it kinda make the slick "bubble" and you would have a small contact area...
with a wider wheel it will "flaten" the slick out and give you a better contact area.
id recomend some lenso's at least... maybe if your budget allows, weld or bogart wheels.
Old Oct 14, 2005 | 01:58 PM
hondaguyef's Avatar
id recomend some lenso's at least... maybe if your budget allows, weld or bogart wheels.</TD></TR></TABLE>
Good Advice. ^^^^
Although I only run M&H slicks, M&H doesn't make a 20" slick. I am still recommending the M/T 20x8's to you at least until you get the 100 shot than move up to 22's or maybe even 23's.
Phil
Old Oct 14, 2005 | 02:17 PM
djsgtrip's Avatar
With 20" slicks, you'll be shifting like a madman. I would recommend a 22x8x13 or even a 22x8x15, either MT or MH.
Old Oct 14, 2005 | 02:48 PM
hondaguyef's Avatar
Default Re: What size slicks for b16 crx? (djsgtrip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsgtrip &raquo;</TD></TR><TR><TD CLASS="quote"> I would recommend a 22x8x13 or even a 22x8x15, either MT or MH. </TD></TR></TABLE>
M&H doesn't make a 22x8x15. Having shorter tires will improve acceleration it's basically changing your gear ratio.
Old Oct 14, 2005 | 03:22 PM
senate33's Avatar
well if someone can find me a cheap set of 22" on a 13 if possible i would be interested in buying them
Old Oct 14, 2005 | 08:02 PM
91' LS-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">M/T 20x8x14. They'll work w/ the nitrous as well (depending on shot size). If over 50 I'd maybe switch to some 22's.
Phil</TD></TR></TABLE>
Hit the nail on the head.
I ran these on my B16 crx with just a header,and managed a 13.7 @ 98mph. Perfect fit for the hp I had. I also have 22's but they killed my traps. 20's are the way to go.
Old Oct 15, 2005 | 04:21 AM
hondaguyef's Avatar
Default Re: What size slicks for b16 crx? (91' LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
I ran these on my B16 crx with just a header,and managed a 13.7 @ 98mph. Perfect fit for the hp I had. I also have 22's but they killed my traps. 20's are the way to go. </TD></TR></TABLE>
Thanks. I speak from personal experience and yet people still question me/ Overlook my advice. Maybe they are more concerned w/ the appearance than the performance
Phil
90whitehatch
10
Mar 30, 2008 09:52 AM
hotimportcrx
Jun 8, 2005 07:27 AM
soulrider4ever
Apr 29, 2004 05:06 PM
r7
Jan 11, 2004 08:58 PM
Nighthawk GS-R
13
Aug 30, 2003 07:54 AM
