which oil should i use for pizza delivery
Old Oct 14, 2005 | 05:06 AM
rolledthatho's Avatar
Default which oil should i use for pizza delivery
hey guys i have an old 89 civic beater i deliver pizza in, my car runs constantly any given night for about 4-6 hours, would i be better off at 10w30 or 40?
Old Oct 14, 2005 | 06:18 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: which oil should i use for pizza delivery (rolledthatho)
valvoline maxlife 10w30 or 10w40 depending how hot it is
Old Oct 14, 2005 | 06:33 AM
jdmitr's Avatar
I always stick with the regular 5w 30 Valvoline or the Max life. 10w is too thick IMO. Use what Honda uses as far as weight is concerned. Plus most Honda dealers get the regular Valvoline in bulk.
Old Oct 14, 2005 | 07:41 AM
Aquafina_Powered's Avatar
My friend who works at Pizza Hut told me they make oil specifically for delivery drivers. It's in your cooking aisle.
Old Oct 14, 2005 | 08:33 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: which oil should i use for pizza delivery (Aquafina_Powered)
Use M1 0w-40, It's an ACEA A3 oil. When used with a good filter, That stuff is good to about 8k mi.
Old Oct 14, 2005 | 09:34 AM
vtecn8ive's Avatar
Default Re: which oil should i use for pizza delivery (LSVT3K 91 C1V1C)
stick with 5w 30. its good for the bearings unless it has hell of miles then start using 10w.
Old Oct 14, 2005 | 04:28 PM
CRXB16T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina_Powered &raquo;</TD></TR><TR><TD CLASS="quote">My friend who works at Pizza Hut told me they make oil specifically for delivery drivers. It's in your cooking aisle.</TD></TR></TABLE>
Yeah that stuff is awesome I run it in my car!
Old Oct 14, 2005 | 04:34 PM
Banned
Default Re: which oil should i use for pizza delivery (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">stick with 5w 30. its good for the bearings unless it has hell of miles then start using 10w.</TD></TR></TABLE>
5w and 10w is just the difference in the pour point in colder weather.. has <u>nothing</u> to do with being bad on bearings.
Check out http://www.bobistheoilguy.com forums for more info.
Old Oct 14, 2005 | 06:45 PM
virginia_dude's Avatar
Default Re: which oil should i use for pizza delivery (CRXB16T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXB16T &raquo;</TD></TR><TR><TD CLASS="quote">Yeah that stuff is awesome I run it in my car!
Don't laugh....I really can run that in the fuel tank of my Benzs by virtue of them being diesels
Old Oct 14, 2005 | 08:10 PM
gutterslide's Avatar
whatever you decide on, buy in bulk. when i delivered, i ran ~500 miles per week. that's 2000 miles a month. oil changes add up quick.
Old Oct 14, 2005 | 08:30 PM
Contender25
Guest
Posts: n/a
I use 20w-50.
Old Oct 14, 2005 | 10:44 PM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: (Contender25)
10w30 or 10w40 should be the only ones you should use, all the others are too thin. Mainly the newly engines need finer and thiner oils but our old engines prefer the thickest.
Old Oct 14, 2005 | 11:47 PM
HxCforever's Avatar
I'm a delivery driver on Mondays for villa Roma. a local pizza place i work for and i use 10w30 full synthetic
Old Oct 15, 2005 | 05:42 AM
Civiclized's Avatar
Pizza hu???
(Use 4.0 QRTS. of regular 10w-40, with .5 qrt. of a 20w-50.This works well in my d15b2 and you can actually feel somewhat of a difference in an economical way)
Old Oct 15, 2005 | 06:11 AM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">
Check out http://www.bobistheoilguy.com forums for more info.</TD></TR></TABLE>
pour point is another way of saying thickness.
it has to do with how cold a "cold start" is in your area.
Old Oct 15, 2005 | 06:51 AM
SomeDude56's Avatar
it really doesnt matter much.
Old Oct 15, 2005 | 07:07 AM
Broke EF's Avatar
Default Re: which oil should i use for pizza delivery (SomeDude56)
just use 10W30 if you go with 10W40 its only gonna make a difference when the oil is cold. Some one already kinda touched on this basicly the numbers are how thick it is in different temps first number is thickness at warm temps and second is thickness when the oil is cold. So if you go with 10W40 its basicly like having straight 40 weight when its cold outside untill the motor warms up then it becomes straight 10 weight. And it wont affect the bearings untill you go to thick i.e. 20W50. There is NO reason to go that thick in regular gasoline motor unless its on its last leg. Heavy oil like that will make your car loose power and gas mileage so who ever said that mixing two heavier oils and said he could feel a difference is either full of it or his car was a POS and he dosent feel the knock anymore.
Sean
Old Oct 15, 2005 | 08:08 AM
CO_RaceFab's Avatar
castrol 20w50 all year baby motor and tranny
thecruzs2007@yahoo.com
17
Dec 29, 2009 10:55 PM
Blaziniflo
28
Aug 15, 2005 07:03 PM
N20civicB18
Jun 7, 2005 10:27 AM
jdmIScool
Honda Motorcycles
19
Oct 1, 2003 09:51 AM
BoBo Racing
Honda S2000
Aug 24, 2003 07:03 PM
