f22b DOHC ECU???
Old Oct 14, 2005 | 05:01 AM
allshowaccord91's Avatar
Default f22b DOHC ECU???
i have a 91 accord so if i do the f22b DOHC non-VTEC swap will i have to change ECU to adapt to the addition of another cam or what? also, is there any place known of that makes a turbo manifold for this motor, what are the psi limits on this motor, and how easy are parts to find? thanks alot for positive input!
Old Oct 14, 2005 | 10:51 AM
raceACCORDingly's Avatar
Default Re: f22b DOHC ECU??? (allshowaccord91)
p39 ecu.
if you want to run the p14 you will need to run a knock sensor.
the limits to that motor is similar to a f22a/f22bx/h23
Stage5AB
Apr 30, 2026 09:23 AM
acracer2008
Nov 7, 2010 07:51 PM
project93
Mar 19, 2008 06:39 PM
medic4.life
Jun 28, 2007 10:02 PM
scabbs
Oct 19, 2006 05:49 PM
