help me solve an electrical problem (sooooo close) + hints
Old Oct 13, 2005 | 09:03 PM
Turbo Dan's Avatar
Default help me solve an electrical problem (sooooo close) + hints
what is wrong:
*my number one fuse keeps blowing
things that are modified as far as electrical:
*gsr cluster, cut origional harness and wired up correct colors to the gsr harness (has been installed and working for 1 year)
*parts of the engine harness in the engine bay near the fuse box do not have loom over them
*start button is hard wired into ignition through a relay so when you have the key in the on position the button starts the car.
clues and what happens:
*can put the key in and turn on accessories and everything works with no blown fuses, and can start the car and idle the car with no blown fuses
*fuse only blows from driving, sometimes it has blown after a 10 minute drive, sometimes after a 20 minute.
*new discovery, fuse blows after the clutch pedal has been depressed 50% or more in neutral while the car is parked and idling.
*i tried three times, and every time i pushed the clutch in it popped a fuse
*ever since ive owned the car (6 years) i have never had to press the clutch in the start the car, it has always started without needing to press the clutch.
Modified by Turbo Dan at 10:43 PM 10/13/2005
Old Oct 13, 2005 | 09:10 PM
88sohcvteccrx's Avatar
Default Re: help me solve an electrical problem (sooooo close) + hints (Turbo Dan)
look at the wires next to your cluch pedal it sounds like a short to ground or a wire that rubed through and only touches when the pedal is pressed in
Colby Schwedes
Honda Ruckus and Scooters
May 31, 2019 06:02 PM
DC2GSR808
May 6, 2015 09:34 PM
mike03,95civic
Dec 31, 2008 08:11 AM
dabiddan
Nov 23, 2004 11:08 PM
