ITR throttle body onto a skunk2 manifold in a GSR
Old Oct 13, 2005 | 07:19 PM
FULLY_BUILT_NA's Avatar
Default ITR throttle body onto a skunk2 manifold in a GSR
i got a gsr, gonna put on a skunk2 intake manifold soon. this guy is offering me a ITR throttle body
will it fit on the skunk2 manifold easily?
if its obd2 will it work on my obd1 car?
do i need any extra hardware?
what kinda gains am i looking at?
what do i need to look for on the TB to see if its in good condition?
Modified by FULLY_BUILT_NA at 8:36 PM 10/13/2005
Old Oct 13, 2005 | 08:24 PM
1turbodc2's Avatar
yes it will work, and fit on your car, u not going to gain all that much but why not... its only 2 mm larger then the gsr throttle body, u might want to get a itr/ls throttle body bracket and u can reuse your gsr throttle cable.. i have a skunk2 intake, with my stock gsr throttle body, itr throttle bracket, and gsr throttle cable and hondata gasket!! and it works nice, but i don't know how much gain on a n/a motor cause mine is under boost
Old Oct 16, 2005 | 04:39 PM
b.d.racing's Avatar
Default Re: ITR throttle body onto a skunk2 manifold in a GSR (FULLY_BUILT_NA)
If you're going to use the skunk2 manifold make sure it has a place for the itr throttle body bracket to bolt to. A gsr tb bracket and an itr bracket bolt up differently. An itr tb bracket bolts to one of the runners and a gsr bracket bolts onto the tb itself.
DefiantGSR
Jul 23, 2007 08:34 AM
strongarm1731
Jan 21, 2006 09:04 PM
ScottFern
Aug 15, 2003 12:07 PM
I B Z
May 21, 2003 01:44 AM
EkREV
Nov 29, 2001 05:46 PM
