Long Crank Time Before Engine Starts
Old Oct 13, 2005 | 03:49 PM
Sanj's Avatar
Default Long Crank Time Before Engine Starts
Have a 90 Crx Si with b16a swap, seems like the engine cranks along time before it starts, I have a new battery, recently tune, new plugs, cap and rotor, pcv valve,air filter, fuel filter, injectors flushed, throttle body cleaned, injectors flushed.
When it does start after a few cranks, rev kinda high. I think i might try cleaning out my EACV this weekend with some air intake cleaner.
Any other tips would be appreicated.
Thanks
Old Oct 13, 2005 | 03:54 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Long Crank Time Before Engine Starts (Sanj)
check the distributor and the main relay.
Old Oct 13, 2005 | 03:58 PM
Sanj's Avatar
The main relay is new. Replaced it this summer. I swapped the ignition coil and ignitor from another car as well. Maybe crank angle sensor??
NO check engine light on, no codes stored.
Start right away when warm usually.
Old Oct 13, 2005 | 04:02 PM
Kapolei INTEGRA's Avatar
same with my car, i think thats normal with b-series hondas or all??
but yea, in the morning starting takes quite a while and the revs are high, about 1500rpms and drops as it warms...but when its warm the engine will fire up right away and rpms are about 1000 and less. i've had two LS motors in my teg...looks pretty normal to me i guess.
rixceu
Jan 6, 2017 01:27 PM
black94lude
Feb 27, 2014 12:21 PM
Dan_UK
Jan 9, 2006 10:36 AM
ninjapanda
19
Dec 15, 2005 08:55 PM
