what cams with high compression....
hi guys, just a quick question what kind of cams do you recommend other than Crower stage 3, the reason is not to say the crower arent good enough i think i may need more of a cam from what people are telling me current numbers are 205whp 151torque at 8200rpm
setup consist of.
bottom end:
85mm Dart with type r crank.
Corillo rods
all honda bearings water pump and oil pump.
top is type r head with full port job 1mm oversize intake valves crower stage 3 cam-also pistons are 12.5comp endyn roller waves, header is a vibrant 4-1 2.5 collector, 310 Rc injectors, jg intake manifold ported throttle body tuned with hondata s200-i know with a higher redline i can make more power but will the cams be sufficient. thanks again
Modified by eg2.0dart at 10:05 PM 10/13/2005
setup consist of.bottom end:
Corillo rods
JDMH22Prelude
Jun 22, 2006 09:44 AM
jdmGSR.fo0!
Jul 8, 2005 09:23 PM
