K-series: intake manifold tests - 2672cc vs simple build K24 (2381cc)
We were curious what the new intake manifold would do on the 2672cc motor without changing anything. Same 75mm TB on the new intake manifold ran with the same non-optimized IPS-K2 calibration for the displacement. What you're seeing here is a direct comparison on the same dyno isolating the two bottom ends. We ran out of time to test the 105mm TB, perhaps after SEMA.
This is a direct comparison between the new intake manifold against the street 54mm ITB's on the 2672cc motor. We haven't been able to tune the 2672cc motor with drag style 54mm ITB's yet. Cams have been the IPS-K2's for all the recent tests.
Finally, this last graph isolates the new intake manifold against the previous manifold with stock TB on the 2672cc motor.
edit : One additional chart at Black R's request, for a delta comparison on the simple build K24 between manifolds.
-Ron
Modified by edo at 7:08 PM 10/14/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8secEg »</TD></TR><TR><TD CLASS="quote">WOW ! Those #'s are insane !
hell yeah
</TD></TR></TABLE>hell yeah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">Damn that is a lot of torque... Wheelspin galore. Thanks again Ron.
IPS
Pirate</TD></TR></TABLE>
IPS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">Awesome work Ron . Are the itb's Jenveys?</TD></TR></TABLE>
Yes, on a Hayward "street" manifold for the K-series.
-Ron
-Ron
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaCaptain »</TD></TR><TR><TD CLASS="quote">looks like you need to move up your vtec point to 5200 rpm.. But really nice gains..</TD></TR></TABLE>
We didn't tune the lowspeed lobes in the normal, tedious K-series fashion. Actually, we didn't tune at all! This test was just a manifold swap using a basemap calibration for the cams on a different motor.
-Ron
-Ron
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">What is the setup of the 2 motors?</TD></TR></TABLE>
IPS-K2 cams
Eibach EVS w/Ti retainers
Hayward Performance intake manifold w/ 75mm TB
R&D Dyno CNC standard port stock valves
custom 4-2-1 header
Hondata K-Pro
2672cc - 90mm bore x 105mm stroke
Castillo's race prepped 105mm crankshaft
Cunningham Rods
JE custom 14.7cr
2381cc - 87.5mm bore x 99mm stroke
stock K24 crank
Pauter Rods
CP custom (shelf app +.5mm OS and deeper valve relief) 12.2cr
-Ron
IPS-K2 cams
custom 4-2-1 header
Hondata K-Pro
Cunningham Rods
JE custom 14.7cr
stock K24 crank
Pauter Rods
-Ron
Ron , loan me those throttles and horns for a day
I have my own manifold....
I'll do some more pistons for you for the loan
I have my own manifold....I'll do some more pistons for you for the loan
nice
edo a quick question...when are you guys going to test your ips-k2 in a k20a?.all your dynos are in a k20a2...i know they were designed around the k20a2..but i wonder what they will do in a k20a..since results a very good in the k20a2...
Interesting.... I wanna see this thing tuned with the 54mm ITB's and the manifold and the manifold with the 105mm TB.... Shouldnt be to hard to do, should it?
Thanks for posting your results
I can't tell which motor is being dyno'd in the graphs, nor which setup is yielding the greater delta... can you please elaborate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">I can't tell which motor is being dyno'd in the graphs, nor which setup is yielding the greater delta... can you please elaborate?</TD></TR></TABLE>
refresh, images updated.
-Ron
-Ron
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hj. »</TD></TR><TR><TD CLASS="quote">nice
edo a quick question...when are you guys going to test your ips-k2 in a k20a?.all your dynos are in a k20a2...i know they were designed around the k20a2..but i wonder what they will do in a k20a..since results a very good in the k20a2...</TD></TR></TABLE>
http://www.k20a.org/forum/showthread.php?t=5872
This is what you can expect from a K20A with similarly equipped bolt-ons. It's a K20A2 graph, but using a thinner gasket which approximates the native 11.5cr found with the JDM K20A.
We have a few guys that run the cams in K20A's but haven't provided any feedback or dynos to date.
-Ron
-Ron
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">Ron , loan me those throttles and horns for a day
You're in luck Tbone, I just so happen to have an extra set of 54mm Jenvey's:
2 sets single injector
1 set dual injector
As soon as I receive the dual injector setup, I can send the extra set out. The other set is already on a SEMA car. I take it, this will be used for the 300whp B-series project?
-Ron
</TD></TR></TABLE>You're in luck Tbone, I just so happen to have an extra set of 54mm Jenvey's:
1 set dual injector
-Ron
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edo »</TD></TR><TR><TD CLASS="quote">
1 set dual injector
-Ron</TD></TR></TABLE>
RON YOU ROCK!!!!!!!!!!!!
I was actually thinking to try them on the current car for a dyno session. No matter what I change right now weather it be cams or tuning , the power wont go up and the graph curve's stays the same.. I feel that I'm just at max for my 48mm plates now . I'd like to try them out.. If theres an improvement now then I'll def just buy new ones. If not then if you have them available when I dyno the 300 attempt , I'd love to try them again.. I dont want to over extend the favor though so I'll do whatever you can...
I'm glad the last few weeks alot of us here have been giving parts to try or just plain have for testing or misfortunes(see DH racing thread) If the few of us that are doing all this testing can build a trust level and maintain the utmost quality controll when it comes to borrowing parts, we will have a good network for doing some insane tests.
1 set dual injector
