What size exhaust piping ??
I was wondering what size exhaust piping you guys where running with Stock motor and an Intake. I was thinking about going 2 1/2 custom piping not sure if ill loose too much back pressure maybe you guys can help out. thanks
Please do your research buddy...
The OEM exhaust is already 2.5" and is completely stainless steel (not a bad design, but heavy). You don't want to go any bigger if you're fairly stock and NA.
The stock is 60mm, which is about 2.25". Going to a 2.5 full custom wont sacrifice backpressure too much. Be prepared for the noise though.
No problem.
Don't let the E-racers tell you what you shouldn't do.
BTW I'm going 3" full length custom SS with HKS Carbon Ti. 3" It matches my downpipe and test pipe. 2.5" is as big as you need to go if you're staying N/A and relatively stock (I/H).
Don't let the E-racers tell you what you shouldn't do. BTW I'm going 3" full length custom SS with HKS Carbon Ti. 3" It matches my downpipe and test pipe. 2.5" is as big as you need to go if you're staying N/A and relatively stock (I/H).
Soled Out
Feb 26, 2003 07:31 PM
cruzersi99
Oct 15, 2002 11:49 AM
