stock itr fuel pressure?
Old Oct 13, 2005 | 06:42 AM
Black R's Avatar
25 Year Member
Default stock itr fuel pressure?
I always thought it was 38-42psi... dunno why, but I always thought that.
Recently I was flipping through the helms and saw that it's 48-56(?) - I can't remember exactly right now but about 10psi than I thought it was.
I wonder what the difference would be if you ran injectors at 40psi instead of 50... assuming you had 20% larger injectors.... would the atomization suffer?
Old Oct 13, 2005 | 09:02 AM
Eva01's Avatar
Default Re: stock itr fuel pressure? (Black R)
38-40 psi should be right. My car currently reads around 40 psi. The 48-56psi probably is the fuel pressure without the vacuum hooked up.
I would think that even with larger injectors, as long as you were within the range of stock fuel pressure, should be ok.
PS. You haven't fuxors my cams have j00!
Modified by Eva01 at 3:10 PM 10/13/2005
Old Oct 13, 2005 | 09:25 AM
Black R's Avatar
25 Year Member
Default Re: stock itr fuel pressure? (Eva01)
nah man, they are still in the boxes. you need them back?
Old Oct 13, 2005 | 10:42 AM
ZygSpeed's Avatar
The helms numbers are with the FPR vacuum hose either pulled off or pinched.
hksitr
11
Jul 27, 2013 12:07 AM
raverx3m
Engine Management and Tuning
Feb 16, 2013 10:19 AM
aalb1
Nov 2, 2005 10:47 AM
Gs-R_turbo
Dec 3, 2004 05:27 PM
red civic standard
Nov 15, 2004 05:34 AM
