Parting out... sleeved 2.0 ls vtec swap, 9.0:1... je, eagle, jg, skunk2, ctr, arp, gsr tranny, jdm..
<U>built b18c head </U> $900 new price $700
-skunk 2 valve springs
-skunk 2 retainers
-ITR valves
-GSR cams
-lightly ported by automotive machine
-ferrea valve guides
-B&M FPR
-NGK wires
-CTR vtec solenoid
-OBD2 distributor w/ MSD cap
-MSD blaster 2 external coil
<U>B18a block </U> $1600 new price $1500
-Golden Eagle sleeves
-Golden Eagle o-ringed
-00 B20 crank (balanced)
-Eagle H beam rods (balanced)
-JE 9.0:1 pistons 84mm(balanced)
-ACL main bearings
-ACL rod bearings
-ACL thrust washers
-ARP rod bolts
-ARP head studs
-ITR water pump
-ITR oil pump (shimmed)
-tapped oil pan for return
-Greddy timing belt
<U>Misc. Swap parts</U>
-JG edelbrock victor x intake manifold w/ GSR tb $250
-00 GSR transmission (no grinds) $600
-01 GSR axles w/ intermediate $200 new price $150
-Mounts/brackets set $150
-01 GSR shift linkage $80
-OBD2B alternator $100
-Clutch masters stage 5 clutch kit unsprung (balanced) $200
-ACT 8lb flywheel (balanced) $100
-High pressure clamps w/ couplings $100 new price $75
-Oil feed/return lines $75 new price $50
-Skunk2 II cams $400 new price $350
-SFP a/c friendly B series manifold (new) $300
<U>FOR FAST RESPONSE CALL ALEX @ 305-801-1475</U>
Modified by Playero713 at 1:24 AM 10/14/2005
Modified by Playero713 at 12:09 AM 10/18/2005
-skunk 2 retainers
-ITR valves
-GSR cams
-B&M FPR
-NGK wires
-CTR vtec solenoid
-ACL main bearings
-ACL rod bearings
-ACL thrust washers
-ARP rod bolts
-ARP head studs
-ITR water pump
-Greddy timing belt
jrp355
Jul 17, 2013 01:38 PM
Playero713
Oct 27, 2005 11:10 AM
2.0 Golden Eagle sleeved ls/vtec fully built swap... 9.0:1 compression 2500 miles of use... full mot
Playero713
Sep 27, 2005 09:29 PM
