94 gsr coolant line routing question.
Old Oct 12, 2005 | 10:05 PM
greasemonkee's Avatar
Default 94 gsr coolant line routing question.
I have a helms for the 98 teg, but I have encountered something different as I am working on a 94. On the intake manifold there are two coolant lines that run through it, one is for the heater and the other is where I am lost. Might that be the one that routes back to the thermostat housing. It is about a 5/16" size (whatever that is in metric).
Maybe someone would be kind enough to post a diagram.
Thanks for any help.
Old Oct 12, 2005 | 10:16 PM
DA6righthand's Avatar
Default Re: 94 gsr coolant line routing question. (greasemonkee)
there should be one for the heater and one that goes from the imf to the thermostat housing. i think but im not sure, im just remember from when i was last tearing apart a gsr...it should just loop from the imf to the block...
thanx
justin
Old Oct 12, 2005 | 11:19 PM
IN VTEC's Avatar
throttle body
90goldhatch
Jun 10, 2010 09:06 PM
lazyxmofo
Feb 17, 2009 01:41 AM
done
Oct 14, 2005 12:24 PM
