motor suggestions
Old Mar 5, 2002 | 10:36 AM
delcamino's Avatar
Default motor suggestions
need some opinions here.
thesse are going in to a delsol
b20z with vtechead + skunk cams and valvetrain
or
b16 with toda spec b head package
im mostly interested in road racing and tearing up twisties around here
Old Mar 5, 2002 | 10:39 AM
Kamin's Avatar
Default Re: motor suggestions (delcamino)
http://www.crvtec.com
Old Mar 5, 2002 | 10:49 AM
delcamino's Avatar
Default Re: motor suggestions (KAMiN)
so i take it thats a go with the b20?
Old Mar 5, 2002 | 12:20 PM
l's Avatar
l
or
b16..... but if you are interested in road racing and twisties id do my suspension first
Old Mar 5, 2002 | 12:29 PM
delcamino's Avatar
Default Re: motor suggestions (IM ALL SHO)
suspension is already done
Old Mar 7, 2002 | 08:16 AM
delcamino's Avatar
come on guys i need some opinions
this will be on the stock bottom end onboth motors for now
Old Mar 7, 2002 | 09:01 AM
memphiss13's Avatar
if it is a stock bottom end then definitely go with the b16. the frankenstein motors are only going to last if you build it right. stock bottom end on a frankenstein just won't cut it.
Old Mar 7, 2002 | 12:00 PM
delcamino's Avatar
Default Re: motor suggestions (rookie2nr)
thanks thats more of the info im looking for
Old Mar 7, 2002 | 01:19 PM
vovinamer's Avatar
b16.. more reliable it seems and also a dime a dozen.. b20 you'll have more troubles which equals more money to spend fixing those problems.. plus.. b20's are only good for straight line racing it seems.
Old Mar 7, 2002 | 01:30 PM
C1V1C's Avatar
Default Re: motor suggestions (vovinamer)
Go B20, for driving impressions on the track check out:
http://hybrid.honda-perf.org/tech/b2...pressions.html
If your gonna add a vtec head you might as well get an ITR motor, end up costing almost as much and not as reliable in most cases.
sts555
15
Jul 12, 2011 01:27 PM
rhd-jon
Mar 18, 2009 02:37 AM
TwoToes
Mar 18, 2008 06:20 AM
DJslepton
11
May 11, 2006 11:06 AM
theslugbug
16
Sep 26, 2003 01:40 PM
