JDM cluster and Spoon cluster, straight plug-in?
B2: I somehow recall that the JDM cluster required some sort of mod (wiring or fitting) to fit our usdm. Do you recall something like that too? I'm not 100% sure though.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
do
a
search
but a simply answer is yes, it will plug it. Will it all work, no. swap the gauges to the USDM motherboard/white plastic piece.
a
search
I just did a search on JDM cluster and Spoon cluster and it didn't say a whole lot about fitting. Which gauge needs to be swapped to the USDM board? I mean if you have a Spoon cluster, it not only have a different gauge, it lights up different as well (and back ground color) so doesn't this defeat the purpose "somewhat" of buying a Spoon gauge and just swap the gauges to USDM board?
The '96 JDM spec R will plug in AND WORK perfectly in a USDM teg. For all the other years, you have to do the mods outlined above. Correct me if I'm wrong.
Paul
Paul
Paul
Paul
I am curious about this too... I have a Spoon Cluster, but have yet to install it, b/c people have told me I need to modify it. I thought it was straight bolt on.
1 FAST R...
I gave you the instructions!!!!!!! I typed them all up..
you didn't print it or save in in Notepad somewhere???
Your R can't be Real Spoon Then!.. Mine is!
just wait until I post the pic..
hehehehhehehehehehhehehehe
just wait until I post the pic..hehehehhehehehehehhehehehe
DA KING
Oct 30, 2004 02:33 PM
the big ragu
May 6, 2002 06:10 PM
