Teg people were no help!
b16a1...with Y1 tranny(I think). Where my speedo cable goes into the tranny...there are two nipples comming off the tranny. Not knowing where they go...I connected them together
works ok, I think it's makeing VSS code come on. The two nipples look just the same on 90-93 tegs, theirs run to a black canaster. Anyone know what this black box does? name of it?
If it's near the speedo cable, that was designed for power steering in Japan and we didn't get that here in the US, you did great by connecting one to the other.
Thanks.....I still got a problem tho. See, I ever sence I did the swap, I get a VSS code, changed the guages no help. One day I decide to see whats in the tubes, so i poured oil down them because I figured it went to the tranny. Well it seemed to fix my VSS code...lasted for almost a month. Is there any connection between the two,VSS/ oil being poured in?
rasta420
Jul 7, 2002 07:50 PM
