B16A - LSD tranny?
Watsup HT.
Got my new 89' Civic si with a pre-swapped B16A from an XSI with a YS1 Tranny. My question is, do they make a non-lsd YS1? If so, how do I check if I have an LSD or not?
Either it will have LSD stamped on the case...or if that is worn off or not visable, you would need to pull the axles out and shine a light thru the diff. If you can see thru the diff, it is LSD, if not (there is a rod in the way) you have an open diff.
90HFCrX
Feb 15, 2005 10:29 PM
CivicSiR7
Oct 4, 2001 08:13 AM
