EG side markers measurements....
Old Oct 12, 2005 | 05:41 PM
00_whytehatch's Avatar
Default EG side markers measurements....
i need help on the EG sidemarker measurements...need help or point me in the right direction.....thanks...
Old Oct 12, 2005 | 05:46 PM
O16581724 5 2 5's Avatar
Default Re: EG side markers measurements.... (00_whytehatch)
I just ran masking tape from the bottom of the fender line above the bumper across, ran it up from the end of the side moulding, placed the corner of the marker in the corner of what that made and went at the fender with a grinder.
Old Oct 12, 2005 | 05:53 PM
gonna need something more accurate then that.....
Old Oct 12, 2005 | 06:38 PM
88hondahatch's Avatar
this is the one i used and mine came out good, i suggest putting it on a xerox machine that you can scale and making it so the sidemarker fits in the outline on the template. than just cut it in half and than cut out the molding slot and the hole and place it on you're fender, used a sharpie marker to trace a the lines for the hole than use a dremel and cut it out.
Old Oct 12, 2005 | 07:02 PM
Default Re: EG side markers measurements.... (88hondahatch)
now thats what i needed....thanks....a lot...
h22god
May 14, 2016 12:13 PM
555R
Mar 27, 2005 07:50 PM
