Moroso Oil Pan p/n29010 on a B17A (Which pickup if any pickup) Answers
Ok for starters I searched and read many posts before starting this I'm just trying to make a very clear and simple thread to understand what fits and what does not.
Moroso Oil Pan p/n20910 <U>Fits</U> B16, B17A, B18A/B, B20, B18C1, B18C5.
Moroso Pickup p/n 24010 does <U>not</U> fit my B17A or B16A.
Moroso Pickup p/n 24010 will fit on B18C1, B18C5
Do I even need a pick up, people all told me "get the LS Moroso pick up if you have a B16/B17."
Answer: One does <U>not</U> need and aftermarket pickup.)
If you want a Moroso Pick and you have a B16, B17, B18(LS), B20 then get:
Moroso Oil Pickup 24011, I don't know if this works with the RR pan.
The summit application picts below are <U>wrong</U>.
Summit Links:
Moroso Oil Pan 20910
http://store.summitracing.com/...ew=32
Moroso Oil Pickup 24010
http://store.summitracing.com/...earch
Stock B17A Pickup
B17A pan Vs. Moroso Pan
Test Fit on w/ Stock B17A pickup on.
24010 Pickup that i received that won't fit.
Helms Manual Pict. for reference.
Will it work with my stock Pickup?
Thanks,
~Eric
Modified by SwedBoy2999 at 6:23 PM 10/12/2005
Modified by SwedBoy2999 at 8:24 PM 10/12/2005
Modified by SwedBoy2999 at 11:18 PM 10/13/2005
Modified by SwedBoy2999 at 11:21 PM 10/13/2005
Summit Links:
Stock B17A Pickup
Thanks,
~Eric
I used stock pickup in my moroso pan.
http://www.moroso.com/catalog/...10915
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Recommended Oil Pump & Pickup
- Use Stock Oil Pump & Pickup
Maybe you should try to look at the manufacture's website about the product.
if you are going to buy the Moroso pickup, then yes you need the pickup for the LS. The difference isn't in the VTEC/NON-VTEC motors, it's motors with and without the girdle. LS, B16A, B17A do not have girdles while the b18c motors do.
but it does say you can use the stock pickup.
s
s
Gamefreak0109
Jun 30, 2007 11:40 AM
