no heat or air
alright guys did some research and found nothing so this was my last option...ok my buddy has a 91 si and his heat all of a sudden doesn't work and the blower is not blowing air at all so my first guess was his blower, but after replacing it, that wasn't the problem, also maybe it had something to do with the blower that we got from the junk yard so if so can you guys help me help my buddy out thanks
get your hands on a voltmeter and a test light.. if you look there is a plug near the blower motor (blower motor resistor) take your voltmeter and see if you have voltage going to the plug wit the key on, switch on..or take a test light and just see if the fuse is good you can start off there
dderolph
Jun 22, 2013 03:10 AM
imadigitalgod
Jan 16, 2009 12:19 AM
BrenaNickels
Aug 24, 2008 06:10 PM
Metal_SOL
Oct 4, 2002 01:46 AM
