Valve adjustment question
Old Oct 12, 2005 | 03:43 PM
HondaAccordTdR's Avatar
Default Valve adjustment question
I think i might be hearing signs of a valve tap, my question is how much does it usually run to get them adjusted, because i am no where inclined to do this myself. My car is a 95 Accord EX with the 2.2 vtec engine. Anybody else notice this? My car has roughly 150k on it. Thanks!
Old Oct 12, 2005 | 03:44 PM
YeuEmMaiMai's Avatar
Default Re: Valve adjustment question (HondaAccordTdR)
about 120-150 if you do a gasket set with them (I would recommend it)
Old Oct 12, 2005 | 04:56 PM
goowakjai
Guest
Posts: n/a
Default Re: Valve adjustment question (YeuEmMaiMai)
i've been nneeding to readjust my valves for a long time now...how hard is it to do it yoursself? i read over the haynes book procedures several times and it doesnt seem like sumthing thats really hard...i admit im no pro but i can learn and am willing to sepnd all day if needed
Old Oct 12, 2005 | 05:07 PM
HondaTechPro's Avatar
Default Re: Valve adjustment question (goowakjai)
AAdjusting the valves is really not that hard. The most difficult part is getting the right "feel" with the feeler gauge. Also, it helps to have a metric feeler gauge, but it's not crucial. Other than that just follow the steps in the service manual exactly and you should be fine. Just remember to do it with the engine cold.... not more than 100 degrees. Good Luck.
Old Oct 12, 2005 | 07:44 PM
FG Two's Avatar
Default Re: Valve adjustment question (HondaTechPro)
my local honda dealer just adjusted my valves for $87!!!
i didnt want to screw anything up myself so i let them do it
Old Oct 12, 2005 | 08:33 PM
goowakjai
Guest
Posts: n/a
Default Re: Valve adjustment question (Phat4drVtec)
87? dats not bad, how long did it take em?
Old Oct 12, 2005 | 10:13 PM
deserthonda's Avatar
should be around 80-90 dollars.......
Old Oct 12, 2005 | 10:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goowakjai &raquo;</TD></TR><TR><TD CLASS="quote">i've been nneeding to readjust my valves for a long time now...how hard is it to do it yoursself? i read over the haynes book procedures several times and it doesnt seem like sumthing thats really hard...i admit im no pro but i can learn and am willing to sepnd all day if needed</TD></TR></TABLE>
first thing u do is get a set of go-no-go feeler gauges ,that way u dont have to work with the feel of the gauge it makes adjusting valves much easier especially for beginners ...
Old Oct 12, 2005 | 10:26 PM
Heat's Avatar
Default Re: Valve adjustment question (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">should be around 80-90 dollars.......</TD></TR></TABLE>
(or for HondaTechPro)
Is adjusting the valves something you would recommend as a matter of routine maintenance, even if the car seems to be running fine? I've got a '99 LX I4 and, the maintenance schedule for normal conditions has adjusting the valve clearance at 105,000 miles or 84 months (seven years).
I bought my car in Oct '98, so its in its 84th month. It has ~ 76,000 miles on it, but it seems to be running great.
I know my local Honda dealership likes to do this every 30,000 miles if you take it in and say "I'd like the 30,000 (or 60,000 or 90,000) mile maintenance", but I suspect they like to do it because it's more work for them to do. Not a knock on Honda dealers in general, just my local dealer.
Old Oct 12, 2005 | 10:42 PM
it is a good maintanance to adjust valves ,,,in most cases ,unless very tight u will not notice any change in the engine performance ..u will hear some tapping noise if loose .. i would advice to do every 30k especially if u do it urself .. if u got to pay a shop i would go to 60k, no longet than that ,unless u start hearing some tapping noise.than do it sooner .. i remember the older cars Honda wanted the valves adjusted every 15k ,,,with every service..
Old Oct 12, 2005 | 11:05 PM
Schmitey's Avatar
Default Re: (deserthonda)
what do you mean by go no go feeler guages?, the one I got is just the different strips of metal
Old Oct 12, 2005 | 11:12 PM
it has a thinner and a thicker part to it ,for example u want to adjust exh on a mmmmm 90 accord at .012 .... u would use the go-no go ... .011-.013 ..it slides real easy in the first step but wont go over the second thickness makes adjusting valve easier and quicker,,this way u dont have to dick around with the right feel .........ask ur snap-on or matco tool guy .. i have been using them for years, work great
Old Oct 13, 2005 | 06:12 AM
killah3084's Avatar
i need to do it to on 93. KELLY HONDA Dealer quotewd at 99.95
Old Oct 13, 2005 | 11:40 AM
FG Two's Avatar
Default Re: (killah3084)
i know on the 5th gens, it is recommended that the valves be adjusted every 30k miles!
Old Oct 13, 2005 | 01:48 PM
Stealthman80's Avatar
Default Re: (Phat4drVtec)
yeah my 93 the damn engine sounds like a deseil at idle, the vavles need adjusting bad but im getting the timeing belt changed real soon so thats getting dont at teh same time
Old Oct 14, 2005 | 01:12 AM
goowakjai
Guest
Posts: n/a
Default Re: (Stealthman80)
since we're on the sbject of maintenance, when shud dist. cap, rotors, and plug wires be changed?
SOHC_me
Jul 15, 2007 03:30 PM
copeman
May 7, 2007 07:11 PM
miksew
Oct 27, 2006 06:50 PM
_Endless_
Aug 18, 2003 12:53 AM
nY's FiNeSt
Jul 7, 2003 09:07 AM
