I HAVE SEARCHED!!! putting drag gen 3 kit on 95 EX coupe need specific answers!!
Old Oct 12, 2005 | 03:26 PM
Firstoost's Avatar
Default I HAVE SEARCHED!!! putting drag gen 3 kit on 95 EX coupe need specific answers!!
I need to know what the stock fuel pressure is on a d16z6. And if i need to, how to reset the new pressure regulator that came with my kit(or since the turbo kit is for a 95 EX would the regulator already be set for the factory psi?). I have the FMU and would also like to know if there are any specific things i need to do to it (other than bolt it on with lines and such) I have a Drag High flow 4 into 1 cast iron turbo exhaust manifold, Turbonetics T4/T3 High flow turbocharger assembly, Turbonetics Deltagate Mark II Wastegate (7 PSI Spring), Drag High Flow front mount intercooler w/ polished cast aluminum end tanks, BLITZ Super Blow Off Valve, Drag mandrel bent high flow chrome plated intercooler pipes, Drag mandrel bent high flow exhaust down pipe, Drag wastegaste dump tube assembly Drag Blue silicone hose and hose clamps, Drag High pressure/High volume inline fuel pump, Drag Boost dependent FMU, fuel regulator, Intake air filter assembly, Map sensor bypass valves, Stainless steel braided oil feed line w/ fittings, Oil return assembly All nessasary hardware and fittings All nessassary hose and hose clamps All nessassary gaskets, and that's it.
Old Oct 12, 2005 | 04:01 PM
beaneg6's Avatar
Default Re: I HAVE SEARCHED!!! putting drag gen 3 kit on 95 EX coupe need specific answers!! (Firstoost)
i think the fuel pressure stock is 42
Old Oct 12, 2005 | 09:54 PM
Firstoost's Avatar
Default Re: I HAVE SEARCHED!!! putting drag gen 3 kit on 95 EX coupe need specific answers!! (beaneg6)
thanks...anyone else know so i can go off of a couple of peoples opinions?
sir00
Feb 26, 2006 03:28 PM
tha-Gr8-one8
Sep 21, 2005 03:41 PM
G_moneydc2
Sep 6, 2005 11:18 AM
Fink2iCe
Aug 11, 2004 12:36 PM
spectunedphil
Oct 18, 2002 03:24 PM
